Roban Apache 700 size build
  • Tooeleflyboy
    CS Agent
    • 508
    Starting to put together the Apache 700, lots of parts to this big boy.
  • Tooeleflyboy
    CS Agent
    • 508
    Upgraded main gear set from Quick UK very good quality
    • Tooeleflyboy
      CS Agent
      • 508
      Mechanics are coming together
      • Tooeleflyboy
        CS Agent
        • 508
        Motor installed and belt tension set correctly, belt tracking centered on the drive gear. very Important !!
        • Tooeleflyboy
          CS Agent
          • 508
          Wiring all coming together, solderd on bullet connectors and EC5 plugs really sucks ! Went to do a voltage test on my leads coming off for the UBEC's and fried one JST plug ... nobody is perfect !
          • Tooeleflyboy
            CS Agent
            • 508
            I plan to fly and tune the mechanics/gyro on a test board before installing into the body.
            • Tooeleflyboy
              CS Agent
              • 508
              The factory finish from Roban leaves a lot to be desired. Cheap easy fix ? Yes ! camo green spray paint from Wal-Mart is a close match and looks great for a base color. Plan to weather this baby up real good !! I added a small chrome strip to the inside of the windows for a start on detailing and it looks close to the real thing.
              • icepirate3
                • 214
                Wow, that looks like a fun build! I will be following this as hopefully some day the finances will allow me to get one. Is the Huey in the background a Roban as well? That's what I plan to build in the future.
                • Tooeleflyboy
                  CS Agent
                  • 508
                  Yes that is the 600 size Huey back there, flies very well I just need to finish up details on the outside and the interior but I will start another thread for that one.
                  • Tooeleflyboy
                    CS Agent
                    • 508
                    So far this will be my basic layout for the batteries and ESC, looks like it will work out pretty well. I have been told the interior can run hot so I have punched some holes into the sides and intend to add some cooling fans to combat this. The holes alone will allow more air to circulate around the batteries.
                    • Tooeleflyboy
                      CS Agent
                      • 508
                      So here is my cooling system for the interior to keep the temps down on all the electronics, Cut open the sides to access the engine or turbine area for the heat to exit out of. Found some small 5volt computer fans and used garage door foam seal to create a nice pressure fit and they will blow the hot air right out the back through the exhaust.
                      • Tooeleflyboy
                        CS Agent
                        • 508
                        Bench test of the mechanics https://www.youtube.com/watch?v=WlwH9_cN3SQ
                        • Tooeleflyboy
                          CS Agent
                          • 508
                          Day Bright lighting system GT 3W kit https://www.youtube.com/watch?v=84REN_CixW4
                            • 2817
                            • Arlington, TX
                            Nice work so far! Really looking forward to the build! Just picked up the 700 Cobra myself for a winter build.
                            • Tooeleflyboy
                              CS Agent
                              • 508
                              Weekend progress.
                              • Tooeleflyboy
                                CS Agent
                                • 508
                                Ordered some lens covers for the strobe lights will see how they work out.
                                • Tooeleflyboy
                                  CS Agent
                                  • 508
                                  getting closer to a test flight ! gyro is programmed and everything checks out so far.
                                  • Tooeleflyboy
                                    CS Agent
                                    • 508
                                    Started getting the body together today. Had to do some shaping to get the tail to fit just perfect but so far so good and it is nice to see it sitting on the landing gear !
                                    • Tooeleflyboy
                                      CS Agent
                                      • 508
                                      Had these pilots made for my 600 size Huey but dang ! I think I can make them for for the Apache as well. They are from http://realmodelpilots.co.uk/
                                      • JFandL
                                        • Jun 2013
                                        • 402
                                        So how's the build going?
