Roban Apache 700 size build
Have you got your(Math) gears setup for your castle done yet? I would guess 1450 RPM would be max safe target?Comment
My specs are the 450KV motor which is 10 pole, ratio is 13.845 and my RPM is set too 1225 on a 12s setup. You can go 1450 but probably need the 500KV motor for that.Comment
Test bed complete and ready to fly. Now if it will just get above freezing outside I will do a test hover.2 PhotosComment
Having never built anything of this caliber, I would have never thought to build a test bed like that!! That's awesome! Hope the hover goes well!Comment
Got a little more done this weekend, created some light covers for the strobe lights, details to the front, gun installed and working on some tail details. Just keeping it fun.4 PhotosComment
That will be sufficient for scale flight keeps the heat down and the blades will sound more like a real ApacheComment
Working on a complete decal kit for the Apache with Callie Graphics I will let all of you know when it is completed!1 PhotoComment
So I got them from real model pilots over in England and I just gave him overall dimensions and not use scale as that seems to not look as good.Comment
Looks great! I have had my 700 size cobra for almost a year... slowly putting it together (clearly). I like your test bed, I was thinking of doing that myself. What are the dimensions of the base piece? And your skids? (cross pieces and skids)?Comment
So the dimensions on the test bed are set according to when the batteries are placed in it will CG correctly and the main gears are good but these will run making much less noise.Comment
Sorry for no updates in a while been diverted to other projects. I dont have a tooth count but the overall ratio is 13.845. I hope that helps and the pinion is on a belt drive so it does not contact the main gear directly.Comment
