Hello HobbySquawkers,
I am helping a local flyer, JB, get his UH-1D 800 Roban kit in the air. The kit has been assembled, components have been install and configured (outside of the fuselage).
My job is to fit everything into the airframe, wire up the power system, configure the flight controller, and get this ready for a test hover.
I'm looking for suggestion on where to mount the Castle 160HV ESC and Castle BEC. Can anyone share a pic, or suggest a good spot for the ESC (and BEC)?
My thought was to mount this onto the plywood frame just below the main (internal) assembly. I assume it will be ok to extend the ESC/Motor wires (about 6") for this application.
JB's Build
Roban B205 / UH-1D 800 size
Scorpion 4035-500KV (w/stock pinion)
Castle 160HV ESC
12S: (2) Admiral 6S 5000
MKS DS1220 cyclic servo
MKS HBL 980 tail servo
Spektrum FC6250HX FBL
Spektrum iX12
The build is special for JB. He was an Army crew chief and spent a lot of time with these machines in the late 60's and early 70's. Perhaps another veteran or history buff will recognize the emblem on the nose of JBs UH-1D. JB tells me the group was call the 'SnakeDoctors'.
All my RC Heli experience is from electric, collective pitch, model ranging in size from 200 to 700. This is my first time working with a scale model. Thank you in advance for your help.
got2tinkr
JB's Build
Castle 160HV ESC
Spektrum iX12
got2tinkr
