Prob so. Right now it has asymmetrical blades on the 2 blade head as supplied by Roban so gets plenty of lift but I’m partial to the 4 blade setup also. Can’t wait to see what DC decides!
BTW, in case you missed the post, I ordered and received a 4 blade tail rotor assembly from Roban for $160 delivered. It’s for a 5mm shaft so fits 600 and 700 size helis. Scaleflying.de is out of stock but the one they list only includes the hub and slider for the same money. This one is ready to mount on the torque tube.
I do plan on trying the 4 blade head and right now I don't think I will paint it or should I say, let Gravy paint it, I like the camo and that was my original plan last year was to buy the camo version first, and then Gravy had to have a gray one, oh but it does look awesome in gray.................:hugging:
I think it will fly better with the 4 blade head too. I know mine does.
Gravy
I agree with you on that, it looks like its unstable most of the time from the videos I have watched of the 700 Cobra, I think the 4 blade will give it a solid flight and not look so nervous in the air like a shaky pilot holding the transmitter..
Only thing is, the two blades give you a better blade pop sound when you pull colllective.
76 if you can fit them into the blade grips. That's if you're using the same 4 blade tail rotor I am. The blade grips on mine wont fit the 76 I have without a lot of sanding. and if you don't sand them down correctly they will not track.
Flight report. She got her first full flight today, even added a few tail overs. She flew fantastic and stealthy, as in quite. Totally different after flying my rebuilt blade 550x. Today was its maiden also. So now I have 3 flight ready scale 450’s, 3 flight ready scale 500’s and 1 550 flight ready.
need to finish the 600 G-jive and fix the gear on my 600 Airwolf. I will then be done with building helicopters….I swear.
Gravy
Glad to hear it’s flying well! I’m amazed to see how quickly you can finish projects and get them flying. I’m a slow builder, with a bench loaded down with probably 2+ years of Heli projects right now. In the current project cue, I’ve got a 450 tandem HUP Retriever, 500 size UH-34, 500 size AH-6J, 500 size Sikorsky H-5, 600 size Sea King, 750 size Bell 430, 550 size Schweizer 300, 550 size UH-1Y, 700 size Cobra, and a 500 size AH-1Z all in line to get built and detailed up. I may have a problem.. :)
