Heli Scale Quality - Hughes 269 Calypso
  • CM_Aero
    • Nov 2018
    • 183
    • Central Texas
    I just started my add-on helicopter rating (full-scale) in a Schweizer 300, so I "had" to build a scale model. I bought this kit back in December and finally getting around to building it. I got a Blade mCPX BL2 that I thought would fit this kit. Turns out, it did not. The foam between the frame and electronics is thicker than the original mCPX. I found a used one on eBay and bought it. So on with the build. I cut all the plastic pieces out and began to glue each side together. I'll assemble the helicopter once all the parts are glued and then paint after confirming everything fits. I wish these parts were 3DP, but I just saw on their website that they are starting to offer 3DP parts. So thats good. Here are some pictures during the build.
  • tony#1
    • Jun 2021
    • 3
    That is a huge disappointment that the BL2 did not fit. The website definitely states that it is designed for the BL2:
    https://www.ebay.co.uk/itm/184756117...EAAOSwrklVUFq7
    I have found the 3DP (three dimensional printed) landing gear. Were you suggesting that there may be other 3DP parts available in the future?
    https://www.heli-scale-quality.com/h...-mcpx-bl2.html
    Is an update available on your build, please, and were there any instructions and if so did you find them to be useful?
