US Army UH-60 Black Hawk 700 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-SFUH60-7S
Photo Credit Matthew Barrett
The UH-60 Black Hawk is a four-bladed, twin-engine, medium-lift utility helicopter. Named after the Native American war leader Black Hawk, the UH-60A entered service with the U.S. Army in 1979, to replace the UH-1 Iroquois as the Army's tactical transport helicopter. This was followed by the fielding of electronic warfare and special operations variants of the Black Hawk. Improved UH-60L and UH-60M utility variants have also been developed. Modified versions have also been developed for the U.S. Navy, Air Force, and Coast Guard. In addition to U.S. Army use, the UH-60 family has been exported to several nations. Black Hawks have served in combat during conflicts in Grenada, Panama, Iraq, Somalia, the Balkans, Afghanistan, and other areas in the Middle East.
This is the Roban UH-60 Black Hawk Scale 700 ARF in US Army color scheme, a premium scale kit that offers unparalleled detail. From tip-to-tail the UH-60 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
This kit comes with a full scale illuminated detail cockpit with dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Full rear cabin interiors are included (not installed). Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior.
These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The UH-60 really impresses with the highly detailed and accurately scaled down profile.
Features:
- 4 Blade rotorhead and scale carbon fiber rotor blades
- 4 Tail blade head and scale carbon fiber tail blades
- Extremely detailed surface with molded panel lines and rivets
- Completely illuminated scale cockpit
- Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
- Special CCPM mechanics built in the top section like the full scale
- Take off weight of 8.5kg (approximately double of a 700 3D helicopter)
- 1700mm long, 1/8 scale
- Roban UH-60 Black Hawk Scale 700 scale body
- Full 700 size helicopter mechanics
- 4 Carbon fiber rotor blades
- 4 Carbon fiber tail blades
- Complete illuminated scale cockpit
- Helicopter flight controller - we recommend the BavarianDEMON 3X Flybarless System
- Electronic speed control (ESC) - we recommend the Castle Creations Phoenix Edge High Voltage 160A ESC With Cooling Fan
- Battery eliminator circuit (BEC) - we recommend the Castle Creations 20A BEC Pro
- Brushless motor - we recommend the Scorpion HKIII 4035-500Kv brushless motor
- Three cyclic servos - we recommend the MKS DS1220 High Torque Servo Multi-Pack (3 Servos)
- Tail servo - we recommend the MKS DS HBL980
- 12 Cell 44.4V 5000mAh LiPo battery - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery Multi-Pack in series
- 8 Channel radio - select a minimum 8 channel radio with pitch and throttle curves from our Radio Collection
- 8 Channel receiver - select a minimum 8 channel receiver from our Receiver Collection
Product Specifications:
AGE LEVEL: 18 and up
SKILL LEVEL: Expert
BUILD TIME: 4+ hours
| Class / Size | 700 |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Fiberglass |
| Overall Size (L x W x H) | 1910 x 620 x 435mm |
| Flying Weight | 8500g |
| Main Rotor Diameter | 1560mm |
| Main Rotor Blade Length | 700mm |
| Tail Rotor Diameter | 280mm |
| Tail Rotor Blade Length | 105mm |
| Tail Drive Type | Torque Tube |
| Cyclic Servos | 3x Metal Gear |
| Tail Servo | 1x Metal Gear |
| Power System | 450Kv Brushless Motor |
| Electronic Speed Control | 120A High Voltage with EC5 Connector |
| Recommended Battery | 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S) |
| Battery Compartment Size (L x W x H) | N/A |
| Required Radio | 7 Channel |
| Skill Level | Expert |
| Build Time | 4+ Hours |
