Official Roban 700 Size B429 Heli Alps Scale Helicopter ARF Thread
    • 8211
    B429 Heli Alps 700 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-429HA-7S
    This is the Roban B429 Heli Alps Scale 700 size ARF, a premium scale kit that offers unparalleled detail. From tip-to-tail the B429 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
    This kit comes with a full scale detail cockpit with dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Full rear cabin interiors are included (not installed). Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior.
    These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The B429 really impresses with the highly detailed and accurately scaled down profile.
    Features:
    • 4 Blade rotorhead and scale carbon fiber rotor blades
    • 4 Tail blade head and scale carbon fiber tail blades
    • Extremely detailed surface with molded panel lines and rivets
    • Complete 7 seat scale cockpit
    • Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
    • Special CCPM mechanics built in the top section like the full scale
    • Take off weight of 8kg (approximately double of a 700 3D helicopter)
    • 1700mm long, 1/8 scale
    Includes:
    • Roban B429 Heli Alps 700 size scale body
    • Full 700 size helicopter mechanics
    • 4 Carbon fiber rotor blades
    • 4 Carbon fiber tail blades
    Requires:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Expert
    BUILD TIME: 4+ hours
    Class / Size 700
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1870 x 510 x 330mm
    Flying Weight 8000g
    Main Rotor Diameter 1560mm
    Main Rotor Blade Length 700mm
    Tail Rotor Diameter 280mm
    Tail Rotor Blade Length 105mm
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 450Kv Brushless Motor
    Electronic Speed Control 120A High Voltage with EC5 Connector
    Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S)
    Required Radio 7 Channel
    Skill Level Expert
    Build Time 4+ Hours
  • Wgh
    • Oct 2025
    • 14
    I think this is where I can put some pics of mine, please let me know if it's the wrong place?
    I wanted something different, I've done the Bell 222 600 size and two Airwolfs, a 600 and a 700. My last project was a Funkey Jet Ranger, 550/600 using a stretch 500, I had to machine my main shaft and a lot of other parts, milled and machined 500 bottom half 600 top, anyway onto something different.
    So there is no misunderstanding/disclaimer, I purchased this directly from the Roban factory.
    It may be packed differently depending where you buy it from.
    From China to the UK it took 12 weeks as it came by ship to keep the costs down, you need to be patient. The people at Roban give tracking info and regular updates, answering questions and I found them to be genuine suppliers who really do care about their customers. This is based on my own personal dealings with them.
    • Wgh
      • Oct 2025
      • 14
      Whilst working on the nav light wiring, I had to chuckle to myself,,,, There's almost ready to fly and there's almost ready to fly. Mine is the latter as you can see from the pics, it's almost ready to fly.... 😅😁😁😁
      • Wgh
        • Oct 2025
        • 14
        This was a nice surprise, the avionics light up. There's a little module in the console, pre wired, ready to plug into a spare RX channel.
        • Wgh
          • Oct 2025
          • 14
          Landing lights and a spot light, switched separately wired up and fitted.
          I noticed that on the real one there are white flashing marker lights just under each front cockpit door, You can just see them in the middle pic.
          After a little more research on the bell website, it stated that some of the executive 429's have a blue cabin light for the passengers, I wired a spare one in. I've also fitted the batteries this way round to try to avoid the nose weight, bottom line is they don't fit side by side. 😅😂😂
          • Wgh
            • Oct 2025
            • 14
            This is a tethered test of my Jet Ranger from 2019.
            • sfcfury
              • Mar 2019
              • 490
              • Baton Rouge, La
              Looks good! What electronics setup are you going with?
              • Wgh
                • Oct 2025
                • 14
                Align RCM BL 750MX 480KV, 12s 2x 6s 5000Mah batteries, MacGregor brushless digital servos, with a high speed HV2 Brushless servo for the tail. Beast X Plus and Spektrum for the tx and rx.
                • Wgh
                  • Oct 2025
                  • 14
                  This is some of the electronics, telemetry, nav lights and switches for them, a bit of a birds nest at the moment. I don't want to secure everything and then find out some part of it doesn't work 😅😀
                  • Wgh
                    • Oct 2025
                    • 14
                    I've got a build thread running on another heli forum that I use, but I don't know if links to other forums are allowed?
                      • 4829
                      WGH,
                      Welcome to Hobby Squawk, glad to have you onboard.
                      You may post a link to your other forum.
                      Copy the URL from the destination site, click the 'link chain' Icon above, paste the URL, click OK, and close.
                      Any issues let me know.
                      Best, LB
                      • Wgh
                        • Oct 2025
                        • 14
                        That's great, many thanks for the prompt response.
                        Discussion Roban Heli Alps 700 Project Large Electric Helis
