Official RotorScale 470 Size Bell 206 Super Scale GPS Stabilized Helicopter Thread
    • 8211
    Bell 206 Super Scale 470 Size GPS Stabilized Helicopter from RotorScale - RTF - HSM-470-R-JR-CF
    Experience the next level of scale helicopter flying with the RotorScale GPS-Stabilized Super Scale 470 Series. Designed for pilots of all skill levels, this series combines stunning scale realism with advanced GPS and gyro-stabilized technology. Whether you're a beginner or an experienced pilot, these helicopters make scale flight both accessible and exciting. With their large, 840mm rotor size, unparalleled craftsmanship and attention to detail, the 470 series sets a new standard in scale RC helicopters.
    The RotorScale Bell 206 exemplifies the pinnacle of this series, combining exceptional features and meticulous scale details in a ready-to-fly package. Its fiberglass fuselage showcases realistic panel lines, rivets, and exhaust details, complemented by a CAL Fire livery and LED lighting for maximum authenticity. Adding to the fun, the Bell 206 features a functional water drop tank for simulated fire drops, making it as interactive as it is stunning. Paired with GPS stabilization, this model offers seamless performance, adaptable user-friendly operation, and unmatched realism in one incredible package.
    Fly Out of the Box!
    The RotorScale Bell 206 arrives fully assembled and ready to take to the skies. No setup hassle—just charge the battery, install the main blades and you're ready to fly!
    Advanced GPS Stabilization
    Advanced GPS stabilization ensures a rock-solid, beginner friendly flight performance that can also be turned up a notch for more advanced pilots or progressing beginners. Available modes include GPS Mode, Angle Mode and Manual/Traditional Helicopter Mode for a wide variety of skill levels.
    Simulated Water Drops
    Fully functional water tank with pump deliver incredible fun for simulated, scale water drops with the simple flip of a switch.
    High Quality, Detailed Fiberglass Fuselage
    Exquisitely crafted fiberglass fuselage is molded with panel lines, rivet details and also includes exhaust details for the highest level of scale appearance.
    Iconic CAL Fire Rescue Livery
    Stand out with the stunning CAL Fire livery, capturing the authentic style of emergency rescue helicopters for an eye-catching, scale appearance.
    Realistic LED Lights
    LED lighting adds scale authenticity and added visibility for early morning or late evening operations.
    Painted Carbon Fiber Blades
    Realistically painted, carbon fiber main blades provide that extra bit of detail for the maximum in scale appearance.
    Large, 470 Size
    The large 470 size with 840mm diameter main rotor provides impressive stability, power and presence in the air.
    • Completely ready to fly package includes everything you need to start flying right away, just add 4AA batteries for the transmitter
    • Advanced GPS stabilization provides rock solid, steady, beginner-friendly flight
    • Larger, 470 size offers enhanced stability and power
    • Fully functional water tank with pump adds incredible fun for simulated, scale water drops with the flip of a switch
    • High quality and professionally painted fiberglass fuselage is molded with panel lines, rivet details, and also includes exhaust details for maximum scale appearance
    • Realistic LED lighting adds authenticity and visibility
    • Painted carbon fiber main blades offer enhanced scale realism
    • CAL Fire livery for a true-to-life rescue helicopter appearance
    • Three flight modes provide adaptable in-flight choices for pilots of all skill levels – GPS Mode, Angle Mode, and Manual/traditional helicopter Mode
    • Return Home and Land feature ensures safe, easy recovery for beginner pilots
    • Low voltage auto-return home automatically returns the helicopter to land at the home point if the battery voltage drops too low
    • Carbon fiber frames provide superior rigidity while remaining lightweight
    • Brushless main and tail motors for high efficiency and long term reliability
    • Reliable 2.4GHz control provides solid, interference free connectivity
    • RotorScale Bell 206 Super Scale 470 Size GPS Stabilized Helicopter - RTF
    • 2.4 GHz Transmitter
    • Flight Battery
    • Charger
    • Instruction Manual
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner/intermediate
    BUILD TIME :less than 10 minutes
    Class / Size 470 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 850 x 210 x 270mm
    Flying Weight 1400g (3lb 2oz) without battery and without water
    Main Rotor Diameter 840mm
    Main Rotor Blade Length 376mm
    Tail Rotor Diameter 130mm
    Tail Rotor Blade Length N/A
    Tail Drive Type 2205 2450Kv Brushless Motor
    Cyclic Servos 3x 12g, Digital, Metal Gear Servos
    Tail Servo N/A
    Power System 2820 1300Kv Brushless Motor
    Electronic Speed Control 60A, 2-in-1 ESC
    Recommended Battery 4S 4000-5000mAh LiPo Battery
    Required Radio 2.4GHz Radio (included)
    Skill Level Beginner/Intermediate
    Build Time Less than 10 minutes
  • Jwierda
    • Jan 2025
    • 6
    Any news when these will be in stock?
    • EdinTN
      • Nov 2018
      • 8
      Check FB board dedicated to ROBAN 470's RTF - https://www.facebook.com/groups/1097531305486328
      • Jwierda
        • Jan 2025
        • 6
        Any in-flight videos going to post soon?
        • Eagle_7
          • Oct 2024
          • 24
          Now if only the water tank was on a Huey or a H-60. Then I'd buy it pronto!
            • 2817
            • Arlington, TX
            I'd just be happy if there was a PNP version for those of us who would prefer a traditional FBL, and for the tail rotor to be on the correct side. No reason not to run a scale setup (including main rotor rotation) on a setup like this..
            • Jwierda
              • Jan 2025
              • 6
              Totally agree with you on this one! I believe you can still get the fuselage and all the components. Tail rotor should definitely be on the correct side of the boom! I do like the new GPS stuff, great for people like me that have problems with arthritis in their hands and can’t control as precisely like when I was younger before all my joint issues.
              • ckankel
                • Mar 2013
                • 39
                From the flight demo video Motion RC just posted it looks like the collective/altitude stick is self centering. That would be a nightmare in manual mode. Is there a way to quickly disengage that? I suppose you could remove the springs as a last resort
                • DCORSAIR
                  • 1918
                  • Selma, Ca.
                  Wow, very nice little helis but that price will keep me away for now, they do look cool though.
                  • BEBELSEN
                    • Mar 2025
                    Hello,
                    I bought this model but I have a trouble now. It worked perfectly for 3 flights.
                    But now, the green light flashes when the GPS signal has been found, but I can't arm the helicopter. The batteries are fully charged. Do you have a solution?
                    • BEBELSEN
                      • Mar 2025
                      Can i do a reset factory ?
                      • Goop99
                        • Apr 2025
                        • 3
                        • Michigan
                        Oops, wrong thread...my bad.
                        • Cal Fire 205
                          • Jun 2025
                          • 16
                          K
                          Second flight with this heli.
                          Radio will not "Unlock", does temporarily then Locks up again .I hit Run switch, nothing happens.
                          Rebind, radio batteries?
                            • 8772
                            Originally posted by Cal Fire 205
                            K
                            If it's anything like my MD500, just flipping the run switch won't do anything. First you must hook up battery (TX on first, all switches UP, then run switch to OFF) and let it sit there for as long as it needs to acquire all the satellites it requires (watch the blinky light and read the manual to see what the blinky light does when it's "ready"). Then you move the left stick down and to the left for about 3 - 5 seconds. THEN you flip the switch to run. The tail rotor should spin up first, followed by the main rotor.
                            • Cal Fire 205
                              • Jun 2025
                              • 16
                              Thanks xviper for the reply. Got some fresh AAs for the radio and will review the start up procedures.
                              Must be something I'm not doing correctly.
                              Thanks again!
                                • 8772
                                I flew my MD500 this morning. The first flight, it took almost 1 minute before it had enough sats. The second flight took about 30 seconds. It depends on the atmospheric conditions at the time to hook up to all the sats it needs. On this brand of heli, I'm not sure how many sats it needs but on some of my other GPS devices on planes and helis, it can require up to 7 sats even on a clear, cloudless day.
                                PS. Are you with CalFire? I have the Hanger 9 OV-10 Bronco in CDF theme - a beautiful plane. I'm retired from Calgary Fire Dept.
                                • Cal Fire 205
                                  • Jun 2025
                                  • 16
                                  I'm assuming if the helicopter does it's GPS check and acquisition, and the green light flashes, it has found all the satellites it needs.
                                  Maybe not? I'll try again tomorrow.
                                  No, I'm not with Cal Fire, but I am retired from a large county fire department in California. I worked on many assignments for and with Cal Fire.
                                  And yes, that is a beautiful airplane. Good job with the paint and decals.
                                    • 8772
                                    There are a couple types of green flashes. The final "ready" one is a slower single flash. Before it's ready, you may get a faster double flash.
                                    • Cal Fire 205
                                      • Jun 2025
                                      • 16
                                      K
                                      Thanks for that info.
                                      I'll pay a little more attention to the type of flashes presented.
                                        • 8772
                                        Have you seen this video? At about minute 6:00, he goes through the initialization and explains about the satellites and the blinking light better than I can.
