Experience the next level of scale helicopter flying with the RotorScale GPS-Stabilized Super Scale 470 Series. Designed for pilots of all skill levels, this series combines stunning scale realism with advanced GPS and gyro-stabilized technology. Whether you're a beginner or an experienced pilot, these helicopters make scale flight both accessible and exciting. With their large, 840mm rotor size, unparalleled craftsmanship and attention to detail, the 470 series sets a new standard in scale RC helicopters.
The RotorScale Bell 206 exemplifies the pinnacle of this series, combining exceptional features and meticulous scale details in a ready-to-fly package. Its fiberglass fuselage showcases realistic panel lines, rivets, and exhaust details, complemented by a CAL Fire livery and LED lighting for maximum authenticity. Adding to the fun, the Bell 206 features a functional water drop tank for simulated fire drops, making it as interactive as it is stunning. Paired with GPS stabilization, this model offers seamless performance, adaptable user-friendly operation, and unmatched realism in one incredible package.
Fly Out of the Box! The RotorScale Bell 206 arrives fully assembled and ready to take to the skies. No setup hassle—just charge the battery, install the main blades and you're ready to fly! |
Advanced GPS Stabilization Advanced GPS stabilization ensures a rock-solid, beginner friendly flight performance that can also be turned up a notch for more advanced pilots or progressing beginners. Available modes include GPS Mode, Angle Mode and Manual/Traditional Helicopter Mode for a wide variety of skill levels. |
Simulated Water Drops Fully functional water tank with pump deliver incredible fun for simulated, scale water drops with the simple flip of a switch. |
High Quality, Detailed Fiberglass Fuselage Exquisitely crafted fiberglass fuselage is molded with panel lines, rivet details and also includes exhaust details for the highest level of scale appearance. |
Iconic CAL Fire Rescue Livery Stand out with the stunning CAL Fire livery, capturing the authentic style of emergency rescue helicopters for an eye-catching, scale appearance. |
Realistic LED Lights LED lighting adds scale authenticity and added visibility for early morning or late evening operations. |
Painted Carbon Fiber Blades Realistically painted, carbon fiber main blades provide that extra bit of detail for the maximum in scale appearance. |
Large, 470 Size The large 470 size with 840mm diameter main rotor provides impressive stability, power and presence in the air. |
- Completely ready to fly package includes everything you need to start flying right away, just add 4AA batteries for the transmitter
- Advanced GPS stabilization provides rock solid, steady, beginner-friendly flight
- Larger, 470 size offers enhanced stability and power
- Fully functional water tank with pump adds incredible fun for simulated, scale water drops with the flip of a switch
- High quality and professionally painted fiberglass fuselage is molded with panel lines, rivet details, and also includes exhaust details for maximum scale appearance
- Realistic LED lighting adds authenticity and visibility
- Painted carbon fiber main blades offer enhanced scale realism
- CAL Fire livery for a true-to-life rescue helicopter appearance
- Three flight modes provide adaptable in-flight choices for pilots of all skill levels – GPS Mode, Angle Mode, and Manual/traditional helicopter Mode
- Return Home and Land feature ensures safe, easy recovery for beginner pilots
- Low voltage auto-return home automatically returns the helicopter to land at the home point if the battery voltage drops too low
- Carbon fiber frames provide superior rigidity while remaining lightweight
- Brushless main and tail motors for high efficiency and long term reliability
- Reliable 2.4GHz control provides solid, interference free connectivity
- RotorScale Bell 206 Super Scale 470 Size GPS Stabilized Helicopter - RTF
- 2.4 GHz Transmitter
- Flight Battery
- Charger
- Instruction Manual
- Four (4) AA batteries for the transmitter - we recommend Admiral 2600mAh 1.2V NiMH AA Rechargeable Batteries (4 Pack)
AGE LEVEL :14 and up
SKILL LEVEL :beginner/intermediate
BUILD TIME :less than 10 minutes
| Class / Size | 470 Size |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Fiberglass |
| Overall Size (L x W x H) | 850 x 210 x 270mm |
| Flying Weight | 1400g (3lb 2oz) without battery and without water |
| Main Rotor Diameter | 840mm |
| Main Rotor Blade Length | 376mm |
| Tail Rotor Diameter | 130mm |
| Tail Rotor Blade Length | N/A |
| Tail Drive Type | 2205 2450Kv Brushless Motor |
| Cyclic Servos | 3x 12g, Digital, Metal Gear Servos |
| Tail Servo | N/A |
| Power System | 2820 1300Kv Brushless Motor |
| Electronic Speed Control | 60A, 2-in-1 ESC |
| Recommended Battery | 4S 4000-5000mAh LiPo Battery |
| Battery Compartment Size (L x W x H) | N/A |
| Required Radio | 2.4GHz Radio (included) |
| Skill Level | Beginner/Intermediate |
| Build Time | Less than 10 minutes |
