Official RotorScale 470 Size Airwolf Super Scale GPS Stabilized Helicopter Thread
  • AlreadyReadyAlready
    The wheels were all the way up on my heli when I unboxed.
  • garshompilot
    I noticed that the landing gear switch on the the transmitter has 3 positions. When the swich is in the up position the landing gear is down. pushing it down one detent causes the landing gear to partially retract and then all the way down it retracts compltely.Not sure if they use the 2nd position on the switch to pack heli into the box or not,
    My landing gear was malfunctioning upon unboxing due to a loose grub screw on the rod to the right of the front wheel. It caused the front and left wheels to extend only halfway and not all the way to the locked position. Those two wheels were also moveable when extended until I called and talked to Tim at Motion RC, who directed me to tighten the Allen key.
    Click image for larger versionName:	Landing Gear Repair.jpgViews:	2Size:	169.2 KBID:	419763
    I am glad I noticed the issue, as it could have resulted in a rollover when landing the heli.
    My tail started to split when threading in the tail support rod. I only threaded it in about half way and then bent the rod a few degrees to compensate for the remaining length. The windows do have film on both sides. I had to use a table vice to press the side gun rods into the outer covers albeit very gently and carefully.
    Click image for larger versionName:	Tail Bar.jpgViews:	2Size:	125.9 KBID:	419764
    ​garshompilot, I have the same question!
    I considered cutting some foam away to make room for the extra parts.
    Also, when transporting, should the landing gear be up and rest the weight of the heli on its belly? Or down? Can the landing gear take the shock of bumping along in a box in the car while driving to and from your flight site?
  • garshompilot
    Was curious how you transport heli. When you add the guns and pods it no longer fits in the styrofoam that it came in. Any thoughts?
    Hi Air-Furbanator, I was told about 10 minutes flight time. I received mine yesterday and am building as time permits. I'll try to get some average flight times. Ensure your battery charger says FUL before flights. Did you have any trouble with the tail splitting while installing the "wheelie bar"?
  • Air-Fubanator
    fully charged battery , hovered in video , than got to somewhat fly for about 2 minutes and went into RTH mode...
    Does anyone know what the RTF Volts is set to?
    or what is considered average flight times?
  • Air-Fubanator
    Part3 coming soon!
  • Air-Fubanator
    Should be here Sunday , Been wanting a great scale AirWolf for a Long time, This is the one I hope 🙏
  • ASCII
    Woah! The only thing missing is the transmitter start playing the Airwolf Theme Song when you power it up!
  • Jwierda
    Notice from the pictures of this in flight, the tail rotor has a chipped propeller, don’t know if you realized it or not
  • Official RotorScale 470 Size Airwolf Super Scale GPS Stabilized Helicopter Thread
    Airwolf Super Scale 470 Size GPS Stabilized Helicopter from RotorScale - RTF - HSM-470-R-AW
    Experience the next level of scale helicopter flying with the RotorScale GPS-Stabilized Super Scale 470 Series. Designed for pilots of all skill levels, this series combines stunning scale realism with advanced GPS and gyro-stabilized technology. Whether you're a beginner or an experienced pilot, these helicopters make scale flight both accessible and exciting. With their large, 840mm rotor size, unparalleled craftsmanship and attention to detail, the 470 series sets a new standard in scale RC helicopters.
    The RotorScale 470-size Airwolf captures the essence of the classic 1980’s TV series helicopter with its meticulously detailed, fiberglass fuselage, complete with panel lines, rivet detail and scale exhaust features. Faithfully replicating the full-scale aircraft used in the show, this model includes accurately detailed ordnance for stunning scale realism. Adding to its lifelike appearance, retractable landing gear operate seamlessly for a fully immersive experience. Equipped with advanced GPS stabilization and multiple flight modes, the Airwolf offers effortless control and adaptability for pilots of all skill levels. Combining exceptional craftsmanship, ease of use, and impressive performance, the 470 size Airwolf delivers an unmatched scale helicopter experience.
    Fly Out of the Box!
    The RotorScale Airwolf arrives fully assembled and ready to take to the skies. No setup hassle—just charge the battery, install the main blades and you're ready to fly!
    Advanced GPS Stabilization
    Advanced GPS stabilization ensures a rock-solid, beginner friendly flight performance that can also be turned up a notch for more advanced pilots or progressing beginners. Available modes include GPS Mode, Angle Mode and Manual/Traditional Helicopter Mode for a wide variety of skill levels.
    Retractable Landing Gear
    Retractable landing gear enhances scale realism and functionality for a more immersive experience.
    High Quality, Detailed Fiberglass Fuselage
    Exquisitely crafted fiberglass fuselage is molded with panel lines, rivet details and also includes exhaust details for the highest level of scale appearance.
    TV Show Inspired
    Equipped with scale ordnance details, the RotorScale Airwolf faithfully emulates the iconic full-scale aircraft from the 1980’s TV series.
    Realistic LED Lights
    LED lighting adds scale authenticity and added visibility for early morning or late evening operations.
    Painted Carbon Fiber Blades
    Realistically painted, carbon fiber main blades provide that extra bit of detail for the maximum in scale appearance.
    Large, 470 Size
    The large 470 size with 840mm diameter main rotor provides impressive stability, power and presence in the air.
    Features:
    • Completely ready to fly package includes everything you need to start flying right away, just add 4AA batteries
    • Advanced GPS stabilization provides rock solid, steady, beginner-friendly flight
    • Larger, 470 size offers enhanced stability and power
    • Retractable landing gear for unmatched scale realism and lifelike operation
    • High quality and professionally painted fiberglass fuselage is molded with panel lines, rivet details, and also includes exhaust details for maximum scale appeal
    • Realistic LED lighting adds authenticity and visibility
    • Painted main blades and tail rotor provide enhanced scale realism
    • Inspired by the full-scale aircraft used in the iconic TV series, featuring stunning accuracy including detailed ordnance
    • Three flight modes provide adaptable in-flight choices for pilots of all skill levels – GPS Mode, Angle Mode, and Manual/traditional helicopter Mode
    • Return Home and Land feature ensures safe, easy recovery for beginner pilots
    • Low voltage auto-return home automatically returns the aircraft to land at the home point if the battery voltage drops too low
    • Carbon fiber frames provide superior rigidity while remaining lightweight
    • Brushless main and tail motors for high efficiency and long term reliability
    • Reliable 2.4GHz control provides solid, interference free connectivity
    Includes:
    • RotorScale Airwolf Super Scale 470 Size GPS Stabilized Helicopter - RTF
    • 2.4 GHz Transmitter
    • Flight Battery
    • Charger
    • Instruction Manual
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner/intermediate
    BUILD TIME :less than 10 minutes
    Class / Size 470 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 890 x 330 x 260mm
    Flying Weight 1600g (3lb 8oz) without battery
    Main Rotor Diameter 840mm
    Main Rotor Blade Length 376mm
    Tail Rotor Diameter 130mm
    Tail Rotor Blade Length N/A
    Tail Drive Type 2205 2450Kv Brushless Motor
    Cyclic Servos 3x 12g, Digital, Metal Gear Servos
    Tail Servo N/A
    Power System 2820 1300Kv Brushless Motor
    Electronic Speed Control 60A, 2-in-1 ESC
    Recommended Battery 4S 4000-5000mAh LiPo Battery
    Required Radio 2.4GHz Radio (included)
    Skill Level Beginner/Intermediate
    Build Time Less than 10 minutes
