Wind when is it to much
  • AkumaZeto
    Achtung Stormtrooper
    • 907
    I normally dont fly above 10mph and it really puts a limit on my flight time. What about you guys?
    AMA 1102566
  • Beeg
    • 1335
    • Texas
    Depends on what I have at the field. I don't like to fly my lightly loaded foamies around 7-8mph. I do love flying my 1/4 Cub gasser up to around 12-15mph though. Makes for some fun times.
    • doctormike
      HobbySquawk Moderator
      • Oct 2013
      • 1260
      • Santa Fe NM
      10 is pretty much my limit. Doc
      • AkumaZeto
        • 907
        All I have is 1400mm fms birds and they seem to be all to light to fly in anything over 5-10
        AMA 1102566
          Flying everyday I've gotten to the point it just doesn't matter anymore, now I don't fly my really nice planes when it's crazy windy but I just came in from flying in 15-20 mph wind and had a ball. I can say that flying everyday has greatly improved my reaction time and understanding of how wind affects a plane.
          • wvrailfan
            • Sep 2013
            • 682
            • West Virginia
            All of my planes are in the 50 to 60 inch wing span class. I can fly in 15 + MPH winds but I don't enjoy it as much, so I tend to fly in 10 MPH or less when I can.
              • 2818
              • Arlington, TX
              I have a few different limits depending on the model I'm flying, but generally I prefer to fly my nicer airplanes under 10 mph. Big, lightly loaded planes like the 1875mm B-17, and Hobbyking Lancaster I only fly under 5 mph. Same goes for my Helis most of the time, just because they are so expensive compared to my planes. Crosswinds also eliminate certian planes from my flight order like the 70mm F-104, or LX F-117. My go to for all higher wind conditions is the 80mm F-86, seems to cut right through the turbulence. Just have to be a bit careful on landing, especially if it is gusty.
              • boomer108
                Chief Boom
                • Apr 2014
                • 868
                • Chicago IL.
                Same here. It depends on what plane I'm flying but normally my max is 10 gusting to 15.
                Roy B.
                • boomer108
                  Chief Boom
                  • Apr 2014
                  • 868
                  • Chicago IL.
                  Roy B.
                    • 7371
                    Call it crazy, but if the winds are blowing the sock straight out, no flying for me. If its a bit less than that. then I take out the Pandoras and hover fly. Fun to do Harrier landings with a Pandora, just have to be quick to grab them when the wind starts pushing them backwards. If its 5-10 mph straight down the runway, then the WB's are okay to go, when it's a crosswind, not so much. I can do a crosswind landing, its just not fun, not yet anyway.
                    Check out some of the Nefi videos from last year. CB does a great vertical landing in his Dynam FW 190. There's a pro !
                    • PappaBear
                      • May 2015
                      • 377
                      • California
                      Flying conditions are generally based on the type, size, and weight of the model you intend to fly. The light and smaller the model the lighter the wind will need to be. A model with a wing span of around 60 to 65" and weighing around 7lb would fly quite happily in a 20 MPH wind. This is also dependant on the skill level of the pilot as well.
                      Martin.
                        I luv flying my TechOne P-40 with 1000mm span in 20-30 stuff. That is what drove my skill set to the higher levels :Cool:
                        • CT
                          • May 2014
                          • 294
                          If over 15 kts I will hanger all birds. Personally I just do not enjoy flying in the wind. It takes all scale out, and are left battling the winds which are absurdly throwing the bird around as it wishes
                            • 7371
                            Some of the younger guys at our field fly the little Parkzone cubs with like a 12" wingspan when the sock is straight out ! They handle it well, so I chalk it up to mindset. I don't like taking chances with a $500 bird in high winds, however, I'll take the Pandoras and have a ball.
                            • Beeg
                              • 1335
                              • Texas
                              LOL! Yeah, couple guys in our club have those little UMX birds with AS3X tech and they fly them in pretty strong winds just for grins. Like you say they do extremely well.
