Nexa 2020mm (79.5") wingspan F8F Bearcat - Balsa ARF
Product Availability: The estimated time of arrival (ETA) for this product is late-May, 2020. Please click the "Notify Me When Back In Stock" button above to receive an email notification when the product is available for purchase.
The Grumman F8F Bearcat was a single-engine American fighter aircraft introduced in late World War II. It went on to serve into the mid-20th century in the United States Navy, the United States Marine Corps, and the air forces of other nations. It would be Grumman Aircraft's final piston engined fighter aircraft. Modified versions have broken speed records for piston-engined aircraft, and are popular among warbird owners.
We are proud to announce Nexa, Motion RC's in-house Balsa-specific brand that will showcase customer-favorites and new, never-before-seen models in various balsa formats and a wide range of sizes and price points.
The Nexa F8F Bearcat is a .33 size electric or gas option scale series warbird with a 2020mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes electric retracts and struts, two piece wing with aluminum wing joiner, flaps, operational gear doors, painted pilot and pre-hinged and installed control surfaces. The large battery hatch affords ample room for either electric or gas setups. An absolute classic at any airfield.
Fully Covered and Detailed The Nexa 2020mm wingspan F8F Bearcat comes fully covered with printed panel lines and rivet detail. |
| Scale Fidelity The classic lines of the F8F Bearcat are faithfully represented, as well as additional details including a painted pilot, operational gear doors, functioning flaps, and a cosmetic radial engine cover. |
Prehinged and Installed Control Surfaces All control surfaces come out of the box fully pre-hinged for your convenience. |
| Operational Gear Doors The Nexa F8F Bearcat comes with operational gear doors that can be servo-activated (servos not included) to enhance the overall scale appeal. |
- Bold and attractive US Navy blue livery
- Electric retracts and struts included
- Complete Balsa and lite-ply construction for rigidity and durability
- Two piece wing with aluminum wing joiners for easy transport
- Operational gear doors that can be activated by servo (servos not included)
- Functional flaps for shorter takeoffs and slower landings
- Replica dummy radial for increased scale appeal
- Covered from tip to tail in scale details including painted pilot and nicely detailed cockpit
- Fiberglass cowling for strength and durability
- All control surfaces come out of the box pre-hinged and installed for convenience
- Large battery hatch allows for your chosen electric or gas setup
- Nexa F8F Bearcat 2020mm (79.5") Wingspan - ARF
- Wheels, wheel covers
- Fuel tank, hardware and decals
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- Brushless outrunner motor - we recommend the Admiral GP26 6330-245kV Brushless Motor
- 80 Amp brushless ESC - we recommend the Castle Creations Phoenix Edge High Voltage 80A ESC
- BEC - we recommend the Castle Creations 20A BEC Pro
- 5x high voltage/torque servos for ailerons, elevator, rudder and flaps - we recommend FIVE Hitec D-645MW High Voltage High Torque Digital Metal Gear Servos
- 2x 45g standard servos for elevator and rudder - we recommend TWO Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servos
- TWO 4 Cell 14.8V 4000 - 5000 mAh LiPo Batteries - we recommend Admiral Pro 5000mAh 4S 14.8V 60C LiPo Battery with EC5 Connector Multi-Pack (2 Batteries)
- Electric propeller - we recommend the APC 19x12 Thin Electric Propeller
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
- 4 stroke engine - we recommend the NGH GF38 38cc Four-Stroke Engine
- 2 blade gas propeller - we recommend the APC 18x10 Gas Propeller
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
.png)
