Want to go to 6s so need to get esc upgrade what 100A should I go with.
Want a 100A esc for p-51 which one
RE: Want a 100A esc for p-51 which one
Castle Creations is the go to from what I have read.Flight Risk (Sean)
AMA # 986105 -
Another vote for CC; I like the fact that most record use info, which may be downloaded to your PC. Things like current, throttle position, rpm, input voltage, and more.Originally posted by FlygirlI agree with Sean.... I'm sure there are other good brands but Castle is supposedly the Cadillac of ESC's.Comment
I've been running the 85a Mantis in my Iron Ass with 5s. Happy with the performance. I have about 15 flights logged.
LonLon
Freewing A-10 80mm, F-86 80mm, F-15 90mm, F-16 90mm. Avanti. FMS DHC-2 Beaver, Fliteline P-38L ,HSD HME-262, HSD F86.Comment
What hobby wing are you using or would use with 6s. It's going in a 1400mm p51Originally posted by PheonixI use Hobby Wing and never had one fail yet. Motion also carries some brand that are very good. I use Castle mostly in my jets.Comment
Are you doing the 580kv motor upgrade?Originally posted by Gas1313What hobby wing are you using or would use with 6s. It's going in a 1400mm p51Originally posted by PheonixI use Hobby Wing and never had one fail yet. Motion also carries some brand that are very good. I use Castle mostly in my jets.Flight Risk (Sean)
AMA # 986105Comment
Hello. you may want to check out the Gecko esc's. I have three and really like the reliability, performance, and cost. They have worked great for me in the 1400 p51d,and 1700p51d. I use an 85amp in the 1400 with a prop mod and 850kv motor, and 125amp in the 1700 w/prop mod. The third is for the 1700 p47 down the road. I recommend getting the programing card also. That way you can set all Gecko's up to your needs. I strongly recommend this product due to the quality,flexibility and cost. Hope this helps.Comment
