Want a 100A esc for p-51 which one
  • Gas1313
    • Apr 2015
    • 6
    Want to go to 6s so need to get esc upgrade what 100A should I go with.
  • STOOPIDMONKEY
    • 319
    RE: Want a 100A esc for p-51 which one
    Castle Creations is the go to from what I have read.
    Flight Risk (Sean)
    AMA # 986105
    • Flygirl
      • 969
      • Glen Burnie, Maryland USA
      I agree with Sean.... I'm sure there are other good brands but Castle is supposedly the Cadillac of ESC's.
      Lauren
      • WintrSol
        • Nov 2013
        • 499
        • Florissant, MO
        Another vote for CC; I like the fact that most record use info, which may be downloaded to your PC. Things like current, throttle position, rpm, input voltage, and more.
        • Pheonix
          • Aug 2013
          • 670
          I use Hobby Wing and never had one fail yet.  Motion also carries some brand that are very good.  I use Castle mostly in my jets.
          • Lon
            • Jul 2014
            • 1201
            • Miles, Iowa
            I've been running the 85a Mantis in my Iron Ass with 5s. Happy with the performance. I have about 15 flights logged.
            Lon
            Lon
            • Gas1313
              • Apr 2015
              • 6
              What hobby wing are you using or would use with 6s. It's going in a 1400mm p51
              • STOOPIDMONKEY
                • 319
                Are you doing the 580kv motor upgrade?
                Flight Risk (Sean)
                AMA # 986105
                • Jack
                  • 17
                  Hello. you may want to check out the Gecko esc's. I have three and really like the reliability, performance, and cost. They have worked great for me in the 1400 p51d,and 1700p51d. I use an 85amp in the 1400 with a prop mod and 850kv motor, and 125amp in the 1700 w/prop mod. The third is for the 1700 p47 down the road. I recommend getting the programing card also. That way you can set all Gecko's up to your needs. I strongly recommend this product due to the quality,flexibility and cost. Hope this helps.
