EDF to Turbine Conversions
  • ticketec
    Yeah we have been flying a turbine converted F-16 V2 for about 6 months now. I made a custom equipment tray for up front,used a custom 1lt bladder tank in the hump because the shape makes standard fuel tanks a compromise, and I made a hatch for access to the tank. lower cheater delete panel and thrust tube support rings for the tail cone. It's a buddy's model but I have 3-4 flights on it now and LOVE it. great fun, It's still on my Tx so will get a few more flights on it soon enough.
    He just flew his turbine converted SR-71 and even though he said it needed a little more work as it was rocking the wings a bit. he said it looked good in the sky. I might get to fly that soon as well.
  • Shaun Evans
    Nobody else?
  • Shaun Evans
    Hi,
    Here's the start to my FW F-16 conversion. After that, it's the F-15, then the Blackbird! All with single X-45!
  • Shaun Evans
    Hi,
    Has anyone converted the Eflite Viperjet, but installed the turbine into the tail?
  • 406PIlot
    Originally posted by Khairil View Post
    Hi everyone. I've just complete restoring the F/A 18 Blue Angels. The jet was not mine but i pick it up (trash) after the pilot crashed it and broke into pieces. Took it home and start to restore everything. Decided to apply the fibre glass and repainted it. From Blue Angels, she is now Grey Ghost 🤣. I am now converting it to turbine. You may also check out the video on youtube https://youtu.be/L-c35Rzu4Vs
    You may also view my other conversion via below link:-
    https://youtu.be/eZvJ11m6L34
    What parts did you fiberglass??
  • Khairil
  • Wingnutz
    Anybody put an X-45 in a FW Venom?
  • Shaun Evans
    Originally posted by T-CAT View Post
    At the 4 hour 38 minute mark in the video below, someone who converted it to a turbine jet using the Xicoy X45 flew at the Horizon Hobby Airmeet 2021 event right after the EDF version flew.
    https://youtu.be/vj6QdLdvvww
    That was a good flight! I wonder who makes a set of wheels/brakes that would work but not add too much weight...
  • Maverick239
    No not yet. One person I fly with did and is supposed to bring it the field today for maiden. The video RcInformer did is great. Look it up on YouTube
    Originally posted by Shaun Evans View Post
    Anyone do the new E-flite Viper yet?
  • Shaun Evans
  • Robert Belluomini
    Originally posted by paulsnapp View Post
    I am new to turbines and want to get a proper refueler. I know Jersey Modeler offers a nice setup for kerosene but way too expensive. Slimline offers a Flilghtline Refueler that is a manual pump setup but advertises it as a Gas refueler. My question is, are the refuelers that can be used for gas safe to use for kerosene. I would not want contamination if the seals, tubing or pumps would deteriorate using kerosene. Any help would be appreciated.
    This pump works Great!
    I have the Slimline can too.
    I use a 2 cell lipo to drive the pump simple and very affordable.
  • Aussie1
    I've just finished my conversion of my Freewing F22 Raptor using a X45 and I must say, it's my best flying small jet yet! Very quiet in the air and the flattened home made pipe fives a real throaty growl at military power!! It balances without lead by having a 2200 battery in the nose cone and my home made one litre tank fits right over the CG and take-off weight is about 4.3kgs, so a 7-10 minute flight is possible. Here are some pictures of the build and a hat-cam video of a flight. https://www.youtube.com/watch?v=uc1Vzg5KxRk
  • Aussie1
    Gas fuel tube and fittings are ok for kerosene and deisal, just make sure you don't have any silicone tubing anywhere. Also a pump suitable for gas and kerosene has to be used.
  • paulsnapp
  • Miroslav Cerny
    Hello to everybody. I would like to install a 4.5 Kg turbine in a Freewing A-10 in one engine nacelle. What should be the angle of misalignment and to which side. Thank you for any feedback.
    Originally posted by 458destroyer View Post
    I am Using a K45-G3
    Gotcha. As mentioned above, HAB has a conversion kit (linked below) for the K30 and K45 specifically for the Freewing Avanti S.
    For product questions and to order, either Tomas or Amir at the email addresses below:
    Tomas: tomas@hab.se
    Amir: amir@hab.se
  • Aussie1
    I am Using a K45-G3
    This one will fit. http://www.grumania.com/xtcommerce/J...KG45::957.html
    Plus, lot's of good imfo here. https://www.rcgroups.com/forums/show...-turbine-power
    https://www.hab.se/bygghobby/hab-cnc/fms-avanti-80mm-turbin-konverteringskitt-komplett-p20-1
  • 458destroyer
    Which engine are you using? That information will narrow the results and help everyone help you .
    I am Using a K45-G3
    Has anyone ordered a thrust tube that was a proper fitment for the Freewing Avanti? I want to order one but there are so many sizes I am afraid to order the wrong one.
    Would really appreciate any links of thrust tubes that fit this aircraft. Thank you in advance!
