Dynam ESC's
  • shakespear
    WarBird Pilot
    • 7
    • Carlisle Aremodelers
    thanks dewey
    • gooniac33
      The Original Gooniac
      • Jun 2016
      • 1047
      Originally posted by farmflyer
      RE: Dynam ESC's
      I had this issue on my dynam 109 the low rpm surge could not be remedied by reprogramming the timing. MRC replaced it with a ZTW esc which cured the problem. The ztw esc had smoother throttle response and also a wider range of throttle allowing for lower and higher rpm than any of my other Dynams. There has been a thread in this forum about the (signal amplifier) I have tried them with or without it and found no difference.
      Sounds like you had it in the wrong PWM setting.
      Dynam makes a decent low dollar ESC! The 60amps have been really good for me with 3-6s applications! I ran one esc for over 5 years pulling 80amps with zero issues! Yes there are better ESCs for more money but is just depends on what you are trying to do...
      • farmflyer
        • Mar 2015
        • 1164
        • Quitaque Texas
        I have had 2 different 40amp dynam esc's that I could not program the low rpm stutter out of. I could change the timing and it only got worse. I could also turn the brake on and off. I reset to factory default still the same. I've decided from now on I'll just buy a replacement when I order Dynam planes.
        • ryramZ
          Pilot Ryan
          • Dec 2012
          • 814
          I always check for a cold solder joint or re-solder the motor bullets if all else fails.
