Some folks may already know what to use to program the Freewing 130A ESC found in the PNP 90mm EDF Freewing jets, while others may not. As you all may be aware of, programming an ESC via the transmitter is a nightmare more often than not. It can be a long and tedious process, and one small mistake can set a person back quite a bit of time and much frustration :D. I found quite a bit of people at my local field wanting to program their Freewing 130A ESC's whether that be for timing purposes, voltage cut-off, etc., and they were doing so via the TX, and giving up on the process. Thankfully, there is a much easier and quicker method, a simple and cheap program card.
To the eye, these Freewing 130A ESC's look like what Hobbywing (the manufacturer of these ESC's) refers to as their Platinum series ESC's due to the casing with the heat sink, coloration of the case, etc. So, it would appear the Hobbywing Multifunctional (aka 3 in 1) LED Program Box would program the ESC. This is not the case and the box will not recingnize the ESC. The Freewing 130A ESC is actually considered a Fly-Fun/Skywalker series ESC in Hobbywing's line-up. Therefore, the cheaper (than the multifunction box) program card works flawless with the Freewing 130A ESC's, and recognizes/changes the necessary settings with ease. The program card is the Hobbywing Card for the FlyFun/Skywalker airplane ESC's linked below. It can be found for between $5-8 from most vendors. Be aware that this program card is sold under various branding simply because the Hobbywing Fly-Fun (which looks to be the replacement for the Pentium and works perfect with this card too) and Skywalker series ESC's are rebranded by many under different names. I've tested this card to work with the following ESC's (please always check for yourself before ordering as some brands have different line-ups of ESC's that need a different card): Hobbywing FlyFun, Hobbywing Skywalker, Turnigy Plush, Exceed RC Proton, Freewing 130A. There is likely many others that work, but I haven't personally tested any others beyond the ones mentioned such as some HSD ESC's made by Hobbywing, etc.
Below are a couple links to the cards that should work just fine (my old Hobbywing-Pentium/Turnigy-Plush card still work perfect with these ESC's too, and is the card that looks the same with the button and light set-up, just different colors and a little thicker casing).
https://hobbyking.com/en_us/turnigy-...ming-card.html
http://www.hobbywingdirect.com/produ...-flyfun-series
http://www.valuehobby.com/hobbywing-...gram-card.html
I hope this helps some of you out. Motion, you should sell these inexpensive program cards on your website, and customer service reps. can also let folks know there are program cards available to adjust their ESC settings. Also, if/once you do start to sell it, a link to the card under the spare parts or upgrades tab for the airplane that has this ESC would be great for easy reference for the customer. Please test this information yourselves though for validity. I have done so myself, but I don't sell these. I noticed you sell the Dynam and Tomcat cards, which appear to be the same. However, if you purchased and sold the Hobbywing Fly-Fun/Skywalker program card, then you can just list the various ESC's it would work with instead of worrying about having several or more branded program cards that end up working the same way for different brands of ESC's. That way it's one part number, one product to order and keep stocked, and one product to maintain the description to add or delete the various ESC's that work with it.
