RX 600SP gyro issues
  • #21
    I will get a picture of how mine is set up tonight and see if we can get to the bottom of this...
    we’ll get you set up.
    • #22
      When I put the reciever into
      Combo B: Gyro Off / Recovery. LED “Pattern” = Red and Green displayed together for two seconds
      Gyro is still always on, after removing the bind plugs solid green light. Gyro should be off.
      I believe this indicates receiver is not operating correctly.
      • #23
ID:	193548 I just realized the videos on UToob are not the ones with Ryan and Mike...
        My plane is set up for Combo C, and truth be told, I seldom use the gyro but it does work well. I found I get the same results with a low rate at 70% and an expo of 20%. When I use the gyro I put it into high rates and expo off. Been awhile since I set it up so I was wrong about the SWITCH setting...yours is ok as mine is same.
        • #24
          The problem with my RX600SP happens regardless of rate or expo setting.
          as indicated I’m my previous post the receiver responds incorrectly regardless of any radio connection.
          I have a DX6 and I'm trying to set up my 600SP on gyro combo C with no luck. I followed the video instructions to the letter but when I'm in combo C I can't get any switch including the bind switch to turn on the gyro, nothing happens, no lights change color, nothing. I did set up the mix just as the video shows. The default
          I have a ticket open with product support and they are looking into the issue.
          Thanks for you help in trying to resolve the issue..
          K
          • #25
            Can this receiver cause severe oscillation(rapidly swaying left to right)? That's what happened on my maiden today. Ended up crashing.
            • #26
              had the gain set to high, back off the throttle will stop it.
              Planes
              • #27
                Thank you. I didn't even check the gains. Left it the way it came from the factory. It's all my fault. Lesson learned.
                How do you check the gains? I think I will have to get a new Lippisch even though there was minimal damage(fingertip lenght broken off one side of the wing and aileron). I was surprise that it didn't even nose dive into the ground. I couldn't find that piece that broke off.
                • #28
                  you adjust the gain by the 3 pots (white circle with the slot, that a flat head fits in too)
                  Planes
