I bought a few of the Eagle A3 gyros (SKU: HEA3STND) to put in my 1450mm FMS birds and have run into a problem. Specifically, I put one in my FW-190 "red 8", which is a 6-channnel plane, and tried to set the Auto-Level function to channel 7. My retracts are on the gear switch, channel 5, and flaps are on the 3-way switch, channel 6. I tried assigning auto level to the trainer switch, like the Eflite Apprentice panic switch, where I am in normal mode when the switch is off and auto-level when the switch is held, but the gyro is not reacting appropriately. When I hold the trainer switch the plane kicks over on its side and it appears to want to hold a knife edge while in a descending spiral (best way I can describe it). In flight, the gyro seems to work well in normal mode, though it was a fairly calm day for wind when I tested it. I did check that the gyro initialized correctly, I set the install position as flat (default), and confirmed the mounting orientation was correct and I did the level calibration (function 9). Is my problem most likely that I am not connecting the gyro's MODE to channel 5 and GAIN to channel 6 as in the instructions? If so, why can't they be assigned to another open channel, especially since the instructions say using them is not mandatory?
Here is my setup:
Turnigy 9x flashed to OpenTx, last stable build
Frsky DJT module
Frsky X8R Rx
Here is my setup:
Frsky DJT module
Frsky X8R Rx
.png)
