I want to put an Ar636 in a new dynam T-28, I'm using a Dx6i. Anyone else using the same setup?
Anyone using the Ar 636 in the dynam T-28?
Re: Anyone using the Ar 636 in the dynam T-28?
My head was put into a spin also. So to start out, and just see how it worked flying. I set mine in the sport mode with the default settings. Well, I have been so satisfied with how the planes have flown with the sport default settings. I haven't attempted to change the settings. Hey, "If it isn't broke, don't fix it"
Hope this helps....I know, when I was trying to adjust settings....sigh...major brain cramps on my part.Lon
after 3 days of trying to program the 636 i found that: 1. set the programmer to run in XP service pack 3 environment, 2.down load the USB interface program and run it in XP mode.
3. If you are programming the 636 for the first time DO NOT plug in external power to receiver as the USB WILL supply the voltage and you can program for the updates to the 636.
4. when using the AS3x program you can use the USB cable on the computer or the AUDIO cable on an ANDROID phone only. iPhone does not work.
i have repeated this several time and found the software was written for XP. it is either glitchy or does not work with Win 7,8,vista,10
.png)
