Setup the A3 per instructions and it worked perfectly on the bench. Correct deflection of all three flying surfaces. Reset gains to about 11 o'clock and had minimal deflection :D Kept it turned off for take off, and when at a safe height, turned it on, and the plane did about 3 perfect torque rolls before I could turn it back off! Landed the plane and reduced the gains to about the 9 o'clock position. Air bourne again at what I thought was a safe height...turned it on and the result was a beautiful spiral nose down into the terrafirma! :huh: Lots of destruction of my foamie twin Duke B60! :@ Any thoughts??
New A3=Immediate Torque Roll!
RE: New A3=Immediate Torque Roll!
gary41, I'm new the whole gyro thing myself. I just purchased the AL-3, Still waiting to install it. But I checked out ALL the Hobby Eagle Gyros before purchasing. Being a tech savey person, the only thing I can think of that might help is check the auto level function for proper set up. What I see in your post is a confused gyro not knowing which way is up so to speak. Just food for thought from a gyro rookie. Good luck, and so sorry to hear about your crash. Happy flying from the pacific NW.Originally posted by gary41Setup the A3 per instructions and it worked perfectly on the bench. Correct deflection of all three flying surfaces. Reset gains to about 11 o'clock and had minimal deflection :D Kept it turned off for take off, and when at a safe height, turned it on, and the plane did about 3 perfect torque rolls before I could turn it back off! Landed the plane and reduced the gains to about the 9 o'clock position. Air bourne again at what I thought was a safe height...turned it on and the result was a beautiful spiral nose down into the terrafirma! :huh: Lots of destruction of my foamie twin Duke B60! :@ Any thoughts??
Pacific NW Flyer :arrow: -
Thanks, Fly Boy; I'll double check everything and install it in a "dispensable" airplane.Originally posted by FLY BOYgary41, I'm new the whole gyro thing myself. I just purchased the AL-3, Still waiting to install it. But I checked out ALL the Hobby Eagle Gyros before purchasing. Being a tech savvy person, the only thing I can think of that might help is check the auto level function for proper set up. What I see in your post is a confused gyro not knowing which way is up so to speak. Just food for thought from a gyro rookie. Good luck, and so sorry to hear about your crash. Happy flying from the pacific NW.
Hey just read on another forum, another guy had the same problem, and he found that his gyro was programmed wrong. He had his gyro installed in an upside down position but didnt switch his gyro mode into the upside down mode. This would explain the gyros confusion. More food for thotOriginally posted by gary41Thanks, Fly Boy; I'll double check everything and install it in a "dispensable" airplane.Originally posted by FLY BOYgary41, I'm new the whole gyro thing myself. I just purchased the AL-3, Still waiting to install it. But I checked out ALL the Hobby Eagle Gyros before purchasing. Being a tech savvy person, the only thing I can think of that might help is check the auto level function for proper set up. What I see in your post is a confused gyro not knowing which way is up so to speak. Just food for thought from a gyro rookie. Good luck, and so sorry to hear about your crash. Happy flying from the pacific NW.
Pacific NW Flyer :arrow:Comment
Thanks, I'll check that also!
Just checked all the programming, and everything is correct. Stabilizer was installed right side up in the cockpit area floor, just about on the CoG, with the pins facing the tail. Maybe I have a faulty unit. I'll remount in a similar model and use only one flight surface thru the stabilizer at a time and see what happens.Comment
Oh thats a great idea, Please keep me informed. I have a SU-26 3-D plane I want to put the A3 in but I'm starting with the AL3 to hopefully get that learning curve in first. Happy Thanksgiving to yea. :DOriginally posted by gary41Thanks, I'll check that also!
Just checked all the programming, and everything is correct. Stabilizer was installed right side up in the cockpit area floor, just about on the CoG, with the pins facing the tail. Maybe I have a faulty unit. I'll remount in a similar model and use only one flight surface thru the stabilizer at a time and see what happens.Pacific NW Flyer :arrow:Comment
did you set the plane level and sync it in the programming?
It sounds like it was set to verticle sync?Comment
Yes, level and sync'd did not do any vertical programming, everything done exactly as in instructions. Gain was set at 11 o'clock positions. Reset gains to 9 o'clock, but have not had chance to fly. Will try again this weekend.Originally posted by mflood3800did you set the plane level and sync it in the programming?
One very important thing is to not move the plane when plugging it in. You will hear the esc do its regular thing but then wait a few more seconds until you hear the gyro twitch the control surfaces. This tells us that now the gyro has been initialized for the flight and is ready. Believe me it's easy to think all's well as soon as the esc chimes "ready" however, it's not. It's happened to me where I was in a hurry and began to taxi before I heard the "twitch" guess what happened plane rolled over and landed inverted. This after spending a lot of time verifying correct directional corrections and calibrating auto level. If you rush ahead of the initialization all bets are off, it won't matter how thorough you were, you will have problems.Originally posted by gary41Yes, level and sync'd did not do any vertical programming, everything done exactly as in instructions. Gain was set at 11 o'clock positions. Reset gains to 9 o'clock, but have not had chance to fly. Will try again this weekend.Originally posted by mflood3800did you set the plane level and sync it in the programming?
RyanComment
not to say anything about these that,s bad but i tried had alot of problems myself finally i got a eagle tree 2d 3d stablizer and all of my problems went away works great now.
[hr]
i just could not get it too work right at all,when i switched to the other gyro i did not change anything hooked it up same as the a1 here , and it flew great i may have had a bad one.Comment
Greetings,
UPDATE: I now have 3 of my planes with Hobby Eagle AL-3 gyros installed. All 3 fly and work great. I have had no problems at all. I did notice though that my gain settings are a little higher on my 1450mm P51 Mustang compared to my 1200mm plane which has the gain turned down a little. On my 1100mm plane the gain is down just a touch more. I think because the smaller planes are more sensitive they dont require allot of gain. Food for thought from the Pacific NW.Pacific NW Flyer :arrow:Comment
I screwed up once and did NOT do the initial stick centering calibration. When I switched the gyro on, it immediately threw the ailerons to max deflections. Not good to do when flying and you are not ready for that action. As soon as I performed the stick centering cal actions all was well again in the world.Addicted to planes!Comment
