Is anyone else having any problems with blown TT-25's with the Aspire Sound Card?
A couple of days ago, I flew one of my B-24's that has the Aspire Card, with the multi-engine sound pack and 2 TT-25's. On the third flight, the sound quit mid flight, and after taking it home and checking, BOTH TT-25's were deader than a door nail. This was probably the 20th flight or so and my other B-24 has about the same flights on it with no problems. I've been using these sound cards for about 3 years and have 4 planes with the older V.4.1 cards with 2 transducers and those planes between them have over 100 flights with never a problem The board is slightly smaller (so it fits in tighter spaces) and the sound is good (no whistles though), but not quite as good as the Aspire card. The V 4.1 has been discontinued however.
I also have 4 Aspire cards and since they first came out, I've had multiple issues. I used to get them directly from Andrew and MR RC Sound, but he stopped selling direct recently and MRC does it-which is fine with me. The first 3 Aspire boards I had would fry a transducer within the first 3 flights. Andrew eventually replaced all my parts but I think he got tired of dealing with me. He told me that on some, he had gotten a bad volume knob, which he replaced on a couple of mine that were bad. He also replaced some TT-25's cause he told me he had a couple issues with the manufacturing and 1 batch was bad. He also reduced the voltage adjustment pot (whatever that is) on a couple that were bad.
In the meantime, on all my set-ups, I added heat sink to all the TT-25's and put "hood scoops" on all planes to channel cool air (as if we have any of that in Florida), directly on the TT-25's and the board. Since doing that, I haven't had a problem. Then, out of the blue, I blow 2 at once. I also have the volume reduced to about 75%, just before the point that the volume starts to noticeably go down, as Andrew told me that will reduce the heat levels and output better and there is no real loss in volume. Some sounds heat up the board and transducers more than others, and the "hottest" is the double wasp with whistle-also one of the best.
I just finished replacing both TT-25's (keep plenty in spare's just for this), but each time I replace one, the foam get's a little thinner a weaker. Just glad the board itself wasn't fried, which was my first thought.
Any thoughts out there would be most appreciated. I've attached photos of the TT-25's with the heat sinks and one of my typical "hood scoop" set-up.
