Product Link: https://www.motionrc.com/collections...era-vtx-bundle
This is the world's 1st detachable FPV goggle. You can use it as a headset, or detach the monitor and place it in a tripod as an FPV monitor. With the built-in 3.7V/2000mAh high-capacity Li-ion polymer battery, you can enjoy FPV flying for up to 2 hours, with its very bright 4.3-Inch wide screen providing a great FPV experience. With the DVR functionality you can record the video and share with your friends. The auto-search function makes the goggle extremely easy to bind with any 5.8Ghz video transmitter.
FEATURES:
FEATURES:
- Includes ZOH1000-003 Camera/VTX Bundle
- Record anytime onto your microSD card (up to 32GB) with the push of a button with the built-in DVR
- Detachable 5 inch screen can be used as a monitor on your radio controller or tripod
- Low power consumption, built-in 3.7V/2000mAh high-capacity Li-ion polymer battery, provides up to 2 hours after full charge
- Dual diversity antenna significantly improves video signal range and stability
- Auto-Searching function supports one key search frequency, shows you the working frequency on screen
- 4.3-Inch 800x480 high brightness LCD screen
- Built-in super sensitive 5.8GHz 40ch receiver with RaceBand
- Universal USB charging interface
- Real-time video return, very low time-delay
- Bilingual menu supports both English and Chinese
- 92% transparent without distortion and blur on the edge of screen
- Supports external video signal input
- Supports audio signal output (you can connect headphones)
- Lightweight, ergonomic design supports comfort while wearing
- Xwave 800x480 5in FPV Goggle w/built-in Battery, DVR, Antenna, Monitor Tripod Mount
- ZOH1000-003 Camera/VTX Bundle
- Clover Antenna
- Panel Antenna
- USB Charger
- Video cable
- User Manual
- Portable bag
- Your choice of added FPV-related peripherals.
| Screen Size | 5in |
| LCD Screen Resolution | 800x480 |
| LCD Screen Display Ratio | 16:9 |
| LCD Screen View Angle | 6 o'clock |
| LCD Screen Brightness | 500cd/m² with high brightness backlight LED |
| Video Delay | Video time-delay less than 20ms |
| Lens | 2.8X Fresnel Lens, 92% transparent rate no distort of light |
