Hobby eagle A3S3 Gains. Help please
  • Seaharrierman
    Scale Helicopter Builder/Pilot & Fixed Wing Pilot
    • Jul 2019
    • 45
    I would be grateful for some help with gains. I will be fitting these into warbirds and will use normal, gyro off, auto level and trainer modes
    what is a good starting point for gains?
    I do understand the text in manual correctly. the explanation for Atti gain is the higher the value the faster the model will move around that axis until it reaches the limit?
    • 8766
    I don't use this gyro so I don't understand what you're asking in the last sentence (Atti gain?). However, insofar as gains are concerned for any HobbyEagle, start with around 25% and increase by 2 or 3% until the plane starts to oscillate at high speed, then back it off to the last setting when it didn't oscillate. I don't know if you can do gain adjustment via a rotary knob while flying but that's the best way. If you can't, then you have to adjust the gain each time you land.
    • Seaharrierman
      • Jul 2019
      • 45
      Thanks Atti Gain is a gain that is only valid in trainer mode
      Thanks for the info I will give it a go
