My videos from my new MBM2 is terrible? Flickering and a lot of noise. is the because i'm filming indoor or could it be the sd card?
Mobius mini B awful video
The "class" should be printed on the front of the SD card. Even though some mini-cams state that you can use a "class 4", best results are from class 10 or higher. Also, some cameras are limited by how big the card can be. You need to read your manual to see if there is a size limit to the card. Indoor operation should merely make for a darker video, flickering and other oddities are likely due to something else.
If you bought it from Banggood or AliExpress, it could be a "clone", depending on who the actual seller is.
From 32gb up to 200gb cards should work. Maybe a fw update is needed.
I haven’t fw updated mine yet.
Guess the seller is okay?
https://minidvcameras.co.uk/product/...action-camera/
Being in N. America, I've never heard of that seller.Originally posted by Nikom View PostFrom 32gb up to 200gb cards should work. Maybe a fw update is needed.
Did you by chance, peel off that protective film from the lens?
No, I can't be sure. It's been a long time since I've used a Mobius. I've gone through 3 of them. I finally wised up and went to other min-cams - Runcam2, Sony, Firefly and those all had a protective film on them. Sometimes, they get peeled off along the way - maybe it was a return that got re-sold or someone tested it in the store.
I'm a fan of the Mobius Mini and have about a dozen (a mix of both "A" and "B" models). On the mSetup VIDEO MODES tab, be sure to NOT select the "Extreme Fine" video quality setting (I use the "super fine" setting one notch down). When you hover the mouse cursor over any of the fields, a helpful message pops up. Here is the one for the "video quality setting";
Also, these little guys are power hungry and work best when supplied with a good external 5V source via the USB connection. (The internal battery is not really adequate IMO.)
Hope this helps!
