LED Light Strips
  • Bellke
    • 118
    • AZ
    LED Light Strips
    Can someone off suggestions on adding LED light strips to a plane? Never done anything like this before but interested in doing it to have something available for a night fly. Everything I'm seeing on Motion seems to be landing or nav lights. Any thoughts or suggestions would be appreciated.
    • 4878
    Bellke great modification idea. Most LED light strips you can get online are 12v, so a 3S battery will power those fine. If I were doing this, I'd just strip back the connectors, add lengths of +/- wiring between the strips to wherever you're mounting the light strips. I figure hot glue or CA would hold the strips on your airframe. If you don't want to add a 3S battery pack, you can use your flight pack by tapping into the the positive connector on the cell 3 counting in from the main positive connector lead to the ESC. Make sense? good luck, post pictures. Best LB
    • marbleempire
      • Jun 2022
      Brighter lights tend to blur the dimmer lights, so do some testing to make sure all of your light sources are visible before proceeding with a particular design.
      • marbleempire
        • Jun 2022
        Brighter lights tend to blur the dimmer lights, so do some testing to make sure all of your light sources are visible before proceeding with a particular design. I try to keep my lights simple and easy, I installed vont.com. I`m satisfied with the price and quality. I know a lot of people glue LED tapes to the outside of the plane. This causes a lot of turbulence in the air flowing around the wing and greatly reduces lift. I`d recommend installing ribbons in the fuselage and wings to improve aircraft performance. The lights can be pointed up, down, or inserted sideways into a slot that you cut in the bottom of the wing.
