A3L Never had this happen before!
    • 7337
    So I had my Avanti out at the field last week, flew great until making my final turn for landing. I installed an A3L in her this year and it made all the difference. Suddenly the airplane was uncontrollable and the inevitable lawn dart occurred. I've had this plane for years and know all its idiosyncrasies. This was weird.
    So, I installed the gyro on my Old Crow and the strangest thing happens..
    After checking the wiring I ran the controls with the gyro off all the stick commands activate the correct control surfaces as you would expect. I turn the gyro on to test the control correction from the gyro. When I dip the nose to see the elevator correct, the rudder swings, if I turn the plane from side to side, the elevator moves!!
    Again, I ran through the wiring and everything is correct!?!?
    I've been using A3L's for close to a decade, I must have ten of them and I've never ran across this. Obviously the gyro is junk, but a warning to all, cost me my only jet and an airplane I really enjoyed flying.
    I can't for the life of me figure out what would cause this.
    • 5392
    Sounds like somehow the programing for its mounting orientation, number 8 on the menu, got changed from flat to upright (vertical).
      • 7337
      Now that's a thought!
      I had it mounted vertical, the only plane I've done that so far with was the Avanti. I'll bet you're right, heading for the basement right now.
      Another dumb old guy moment. Still doesn't explain the crash, but hey, sometimes we just don't get an answer. Winter projects are born at the airfield.
        • 5392
        Oh if you have the orientation wrong it will do some crazy things and if you put it into self leveling it was going to crash anything you do…
          • 7337
          Sure as all hell, it works now!
          Thanks!
            • 5392
            A second set of eyes from across the country!
