How r ya guys ,, was going to maiden my new f4 phantom yhis long weekend but na.. in the midst of radio setup noticed at full elevator,, my setup also moved the ailerons.. started out 5 years ago on dynam detrum.. got rid of the planes 4 years ago, but found no reason to change,, ELECTRONICS until now.. my first thought was i had done something in setup.... or was it my new f4 but went thru all models inc the model setups in the dt9 inc non setup planes in the trans.. the channel monitor across the board shows uncommanded aileron movement with elevator up or down.... gota b stuffed,,.... anyway after all that dribble,, ive ordered a spektrum nx7e ... not looking forward to learning new electronics.. not my thing.... so couple questions.. if i use spektrum rex as3x is the gyro adjustable in the tx,, as was in my detrum.. and i think i can use lemon rx( way cheaper but no internal gyro).. and r the lemon reliable as far as signal... not a prob on detrum..... my hanger building and more to come . SO NOT SURE WEATHER TO STICK WITH SPEKTRUM RXES.. OR LEMON, AND USE SEPARATE GYROS (many planes come with gyro now) thanx in advance,,
b safe
