A3 pro gyro
  • Waiting to crash
    • Jan 2024
    • 5
    A3 pro gyro
    So there is only one spot for elirons but my plane has two servos how do I hook it up or can I even hook it up
  • NewbieBob
    Back at it
    • Sep 2022
    • 83
    • Eastern Ontario
    You need to use a Y connector cable that joins both ailerons together and ends up with one plug for the receiver
    • Waiting to crash
      • Jan 2024
      • 5
      That won't work if I do that both elir will work in the same direction
      • Waiting to crash
        • Jan 2024
        • 5
        Remember there are two servos which means two channels eliron and Axl 1
          • 5426
          Then you can’t use that gyro. If they can’t be Y’d then no gyro nor one that can do flaperons.
          • NewbieBob
            Back at it
            • Sep 2022
            • 83
            • Eastern Ontario
            Reverse one aileron servo before connecting to the Y harness or flip the one servo over if possible.
            • NewbieBob
              Back at it
              • Sep 2022
              • 83
              • Eastern Ontario
              If one servo is on its left side and the other on its right side they will move opposite to each other
              • Waiting to crash
                • Jan 2024
                • 5
                So I do away with the axl channel split the eliron and reverse say the left servo and I should b good
                • NewbieBob
                  Back at it
                  • Sep 2022
                  • 83
                  • Eastern Ontario
                  Yup. If they are on opposite sides they will already move differently and just the Y cable should do the trick.
                  • Waiting to crash
                    • Jan 2024
                    • 5
                    Thanks that makes sense
                    • NewbieBob
                      Back at it
                      • Sep 2022
                      • 83
                      • Eastern Ontario
                      Good Luck. Keep us posted
                      • kallend
                        • 1877
                        If you need to have 2 aileron channels (for example, for differential or spoilerons/flaperons) then you need the Hobbyeagle A3S4, which has independent inputs and outputs for 2 aileron and 2 elevator channels.
