Receiver location question
  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    I've got my new F-86 ready to fly but I'm wondering if the spot I choose for the receiver is bad, I think it's in a bad spot.
    This is NOT where the receiver was mounted in the one I lost.
    You'll notice the the antenna wire on the left is under the three wires going from the ESC to the EDF.
    Any one have an opinion on this?
    • 7383
    I try to find a place so that the wires are free and clear, making sure that they're 90 degrees to each other. Sometimes a satellite antennae is a good way to go. As for the F 86, hopefully Lon or Ryan will chime in as they both have extensive flights on theirs. See if you can PM them.
    • Lon
      • Jul 2014
      • 1202
      • Miles, Iowa
      I think it would be fine. Here's a pic of mine. At the very back is my Telemetry module. Then as you look forward there's the receiver with my satellite way up front.
      NOTE: My 4000 battery ends up against my receiver for proper CG.
      Lon
        • 8814
        That looks like a Lemon RX. Is it? Does it have a satellite? I've used a similar RX with sat and the main RX is up against the flight battery, with the battery cables running very close to it. The satellite is usually a bit further away from the main but still right next to the battery. It still seems to work.
        • StormyDog1962
          • 338
          • Naperville Illinois
          That's where I have placed mine and have not had any issues. Your set up looks good and I believe you will be just fine.
            • 8814
            A range check should help reduce some of your apprehension.
            • Lon
              • Jul 2014
              • 1202
              • Miles, Iowa
              Excellent point viper!!!!!
              Lon
              • dkalwishky
                Warbird Lover
                • Sep 2015
                • 1382
                • Des Moines, IA
                It is satellite capable but I do not have a satellite for it. I will definitely range check it. :)
                  • 8814
                  If I'm not mistaken, to get full range you must have a satellite UNLESS you have the newer "diversity" RX, which has the 2 short antennas coming out the same end of the RX. Those are the only ones advertised to not need a satellite even though there is a plug in for a satellite. Personally, I don't like the diversity RX because if one antenna gets a bit loose, it won't even have the range to do a range check. I much prefer the "regular" RX with satellite or the Spektrum ones with the one long antenna that has some kind of lump (range extending resister?) near the end.
                  • dkalwishky
                    Warbird Lover
                    • Sep 2015
                    • 1382
                    • Des Moines, IA
                    Interesting, I've got 5 Lemon's in planes now and none of them have satellites hooked up to them. I will look into that.
                      • 8814
                      Interesting. Are they the diversity types? Have you flown at long distance (ie, beyond 500 feet)? You might be reaching the limit of range without the sat. When you come down, is the light in the RX blinking? That's means it's lost contact momentarily at least once during the flight. At least that's what my Spektrums do.
                      • dkalwishky
                        Warbird Lover
                        • Sep 2015
                        • 1382
                        • Des Moines, IA
                        No diversity's and I've never noticed the RX blinking. I've gone past 500' away from me.
                          • 8814
                          Well, I think if it range checks OK, then not to worry.
                          • dkalwishky
                            Warbird Lover
                            • Sep 2015
                            • 1382
                            • Des Moines, IA
                            I've been reading up on the satellite and when to use them. From what I have found today the consensus is the satellite will not extend range but it will cut down on receiver shading (I guess this is where the signal gets cut momentarily).
                            I will definitely range check before I fly.
                            • WintrSol
                              • Nov 2013
                              • 499
                              • Florissant, MO
                              Don't forget, that model is foam; you can use a pin or toothpick to make a hole for the active end of the antenna, which is only 31mm long, just about anywhere.
