Eagle a3 Gyro set-up
  • Jakeypete
    • Jun 2016
    I have an eagle A3 Gyro, apparently stuck in 3 D mode? Flashing red led. How do I get out. I have tried resetting per instructions. Hold menu button and power up. Doesn't seem to work.
    • 8835
    Do you have the MOD port on the A3 connected to anything? If not, it should default to "normal", which is the blue light. If you have it on a 2-way switch, then you need to have assigned that port on the RX to that switch. Same for if you are using a 3-way switch. If you've assigned the gain to a rotary knob, then you can have 3 of the 4 possible flight modes, depending on how you programmed it. There is no "3D" mode on the A3, only the A3-L. Solid red on the A3 is "auto-balance". I haven't seen a flashing red on either. It might mean something is wrong in the set up.
    As far as I can recall, you don't hold the button as you power up. That menu button is used after it's powered up. Hold it for a few seconds and it goes into program mode. Did you download the manual from the webpage?
