Receiver locations
  • beng
    • 12
    • Middle Georgia
    Receiver locations
    Quick question.....can you location a receiver in the tail area about 3 feet from the motor if you use longer cables? Was told it would be better, it's away from your other electronics and interference Thanks beng
    Maybe if you are using old school tech( 27 or 72mHz) it would be an idea but not a very viable practice due to all the servo extension leads required and not to mention the added weight to the tail.:Scared:
    Todays microwave (2.4gHz) radios are the rock solid standard.:Cool:
    Shorter leads all the way around is the obvious choice in any electrical system.;)
      • 8835
      "Better"? People have mounted RXs close to motors, batteries, ESCs and they have been just fine. Better than fine, good or "never a problem" is hard to quantify. Ask whoever told you the reason for it being "better". Did he have a problem with a particular plane? Is he superstitious? Did he listen to "old wives"? Long cables have been used for a long time, too. It's the connectors in extension cables that might give issues. If it makes you feel better about your flying experience, then do it. Quite frankly, if you don't have a problem, why look for one?
      • Capt. Crunch
        Balsa flies better
        • Nov 2014
        • 388
        • Iowa
        Only time the placement of the receiver becomes an issue is when you have electronic ignition for a gas engine. You need to keep as much space between them as possible to reduce signal interference.
          • 8835
          Originally posted by modaj24451
          Receiver installation and top brands information is here. All those who are waiting for the receiver installation they can make more best dissertation writers and that is ever important to through it to the brands who are at top.
          Give up while you're still behind.
            I'm (moderator) are all over em. Suspect same person now with a second user name.:face_with_raised_ey
              • 8835
              I'm sure there'll be a third and a forth. Some forums can see the IP address and ban anything originating from that IP.
                This forum can see the IP's but the Banhammer resides with Aros and Alpha presently.
                Us mods are the cops and Aros, Alpha and Marco are the judges.
                  • 8835
                  I've always wanted to be an executioner. :skull_crossbones:
