I'm looking for an extension cable that I can use with the LED lights and blue box with Flightline planes. It's a two pin connector. I haven't had any luck finding these, I prefer one that's already assembled.
LED light cable extention
Tags: None
Are the connectors like these JST's?
http://www.hansenhobbies.com/product...ors/jstbec_fh/
Take a look here and see if they have what you're looking for:
Zen Cart! : Down for Maintenance - Battery Acc/Conn Parkzone AR6400/AR6400L Servo Accessories / Connectors Servos Wire/Servo Wire Servo Converters MiniFutaba Servo Connectors 2-2.54mm Pitch connectors -XP-3A Spektrum satellite RX cables Shrink Wrap Custom Orders Banana Jacks Parkzone AR6400LBL Losi Micro-T/B/DT OpenPilot/CopterControl JST connectors TX Battery Pack Connectors Fly-Dream/HK Altimeter Traxxas QR1 CRIUS All in One Pro MULTI-ROTOR AltitudeRC Nano 5.8G FPV TX Immersion/Boscam Vid TX Efllite Blade NanoQX Mid/High Power Battery Connector AIRPLANES HELI Generic Orders Hitec X4 Micro Charger FRSKY XSR Spektrum Telemetry cables 1S Lipo to RX cables Servo Extensions Boats Liftware Steady Utensil Repair JST-ZH ecommerce, open source, shop, online shopping, store
If you can't find what you need let me know and maybe I can make one for you. -
I've attached a picture of the FLRC blue control board. The new 1600mm Spitfire has three wires coming from the board to the receiver, I want to plug an extension in the strobe port so I can attach it to the blue board then do all of the hook ups in the fuse.1 PhotoComment
Gotcha. I take it you only want the single beacon on the fuselage to "strobe" ?
I was going to add the tail position light on my Spits as well so when they get here tomorrow I'll know exactly what is needed. I have JST connectors but if they don't work I can order some extra connectors and make up what is needed.
If you're in a hurry one thing you could do it just take a regular servo extension, take your razor blade and just slice the connector down to two. Just make you sure you slice both ends to have the same wires.Comment
I haven't decided on whats going to strobep and stay steady. I've got spare extensions, I may give that a try. If I fail and you make up some extensions I'd be happy to buy a couple off of you. :)Comment
Have looked for a long time for two pin servo connectors but to no avail so I've been doing what you've suggested Beeg for quite awhile now.
A good sharp pair of mini-wire cutters gets the job done very well also.
I always cut the yellow/white signal wire side off so that the black/brown(negative - ) and red(positive + ) remains as a correct voltage color coding.Warbird Charlie
I finally found the connectors! I ordered mess of them so if trimming a standard servo connector doesn't work I can make one up for you. They're called JWT 2-pin
https://hobbyking.com/en_us/jwt-conn...-5set-bag.htmlComment
Nice job finding them Beeg:Cool:............gotta get me a bunch ;)
OH BITE ME.........figures that they're only avail global and not US warehouseWarbird Charlie
In a pinch, can't you just use a servo extension? Doesn't really matter what color the wires are, so long as you've got it plugged so that you know which is + and -. As for gauge, usually servo wires are heavier, so that shouldn't be a problem.Comment
