Removing Decals from Foam ????
  • goosekiller1
    The Hun in the Sun.
    • 134
    • Santa Rosa CA.
    I'm just starting to remove the Decals from my FMS BF-109 1400mm my local hobby store recommend I use Bob Smith Insta-clean, I tried to take off a decal on the tail did wait 1 to 5 mins no luck. Help needed please any recommendation or tricks I could use would be most grateful for any help.
  • fhhuber
    • Aug 2015
    • 1476
    Apply packing tape, pull back at a sharp angle. It will take off the decal and most of the paint.
    • OsideRCflyer
      • 175
      • Oceanside California
      Stickers will come off with ice being rubbed on them but decals will not. I’m redoing my FMS BF-109 too. Since mine has some “hangar rash” i just took them off and applied spackle on the decal areas and rash. Next step, sand and at least two coats of Minwax Polycrylic brushed on with a sponge brush. Prime and paint.
      • mr.frankenjet
        Eat, sleep, FLY FLY FLY !
        • 448
        • Virginia, USA
        I have found I get the best results by priming and painting over them. No foam damage and it's already smooth.
        rc flyin addict
        • Corsair 167
          Hobby Squawk (EXPERIENCED PILOT)
          • 35
          • Fort Mill, SC previously IN
          I've done this previously with light sanding and paint over them. Spackle from Sherwin Williams not the stuff at wally world.....prime and paint doesn't work
          • AkumaZeto
            Achtung Stormtrooper
            • 907
            Take a can of air duster turn it upside down to get the refrigerant out. Spray upside down. It will freeze decal and then it will peel right off. I used this method for twenty years removing mylar from pinball playfields. Use gloves as can gets cold. PPE and all
            AMA 1102566
            • Prowler901
              • 940
              • Gunnison, CO
              Now that is a clever idea. :Cool:
              • seaviper
                ATC retired
                • Aug 2016
                • 1092
                • Philadelphia Mississippi
                Actually prime and paint does work. But it takes several coats of primer to fill the hole left by ripping off the decal. I use lightweight path and prime from Lowes. It's not a 5 minute solution. You have to patch it, sand, prime, sand prime until it comes out.
                I have had less than good results with ice. But I am sure ice works on the factory stickers. Not so well on Callie Graphics vinyl.
                For removing vinyl without lifting paint, I use a very sharp, new, xacto blade and careful pulling. I have done this many times and it works for me. No paint lifted.
