Elmers wood filler
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    Elmers wood filler
    I've used wood filler on foamies for some time now and it works great. It fills gouges, dents, and scratches, and it's light as a feather. It  sands with ease. When you pull off those pesky non-scale stickers, wood filler realy works to fill in where the paint and foam lifts off. It accepts paint well. Do a little touch up with Varathane water base clear coat (which I coat all my foamies with) and it's good as new! Home Depot is the only place I've found Varathane. Varathane is much better quality than Minwax. The Doctor
  • Lon
    • Jul 2014
    • 1202
    • Miles, Iowa
    RE: Elmers wood filler
    Hey Doc,
    I've used the Minwax, but not the Varathane. In what way do you think the Varathane is much better quality??
    Lon
    Lon
    • doctormike
      • Oct 2013
      • 1260
      • Santa Fe NM
      Varathane seems to be more flexible, leaves no streaking and doesn't have a bubble problem. Minwax is brittle when dry. I wish I had known about Varathane before I started this Minwax craze. The Doctor
      • Lon
        • Jul 2014
        • 1202
        • Miles, Iowa
        thanks Doc!!
        Lon
        • doctormike
          • Oct 2013
          • 1260
          • Santa Fe NM
          Hi, LON   If you, or anyone else, try Varathane water based, let me know what you think of it. Also, if you foam brushed it or air brushed it. Doc
