Thread holes
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Thread holes
    Hey members I'm looking for a good way to fill holes in plastic that will be strong enough to put a screw back into it. We have all had screws strip at one point on plastic mine happens to be at a landing gear . any ideas or thoughts on what to do ?? Thought of glue but at some point I will need to get the screw back out I feel sure of .
    Bryan
    But Crashing is Landing
  • Loneflier
    • Aug 2013
    • 603
    • Huntsville, AL
    RE: Thread holes
    Hey H64,
    I suppose you could try to fill the hole with one of those "metal" epoxies, then once it dries, tap it out and rethread it. Might be easier just to re-tap the hole with a larger size screw thread though.
    • boomer108
      Chief Boom
      • Apr 2014
      • 867
      • Chicago IL.
      RE: Thread holes
      Bryan
      You might try a drop of ca in the threads and let it dry before you put the screw back in. It works on wood.
      Roy B.
      • STOOPIDMONKEY
        • 319
        RE: Thread holes
        you could also try to drip some 5 min epoxy down into the hole let it set
        Flight Risk (Sean)
        AMA # 986105
