When is the next shipment due? I need to replace some recievers in a few of my planes.
Frsky recievers
Tags: None
We should have some of them next week but these FrSky Receivers have not shipped yet: G-RX8 and S8R. We have emailed FrSky to see if we can get an ETA on those. -
I was just at a main and they showed sold out... they only had 1 of the s6r models but I needed 2 receivers for a couple planes I haven't been able to fly for a while.Comment
I have been reading about how to flash the firmware to an SxR receiver from an X10S using a modified servo cable attached to the pins for the external module of the X10S to the SBUs connector on the receiver. I am unclear if you also have to have the receiver connected to a battery as well. Does anyone here know?Comment
No it’s powered by radio. You need to flash external device. I flash all mine thru my x12s. You’ll need a battery to do the calibration afterwards. I use a 6volt battery plugged into receiver and bind it to radio than use lua script to calibrate.I have been reading about how to flash the firmware to an SxR receiver from an X10S using a modified servo cable attached to the pins for the external module of the X10S to the SBUs connector on the receiver. I am unclear if you also have to have the receiver connected to a battery as well. Does anyone here know?Comment
