Trim adhesion
  • Carl Martin
    Trim adhesion
    It sounds like there's lots of heartburn over trim coming loose, especially on Flyzone. I found that going over the trim with my Monokote iron set to 150 to 200 degrees will activate the cement and solve the problem. Don't use too much heat or a heat gun. The trim will curl. The adhesion is such that the film can still be peeled off without heating, re-positioned and re applied woth heat. I just removed all the trim on a Sea Wind and transferred to a new fuselage (the $&"@#% reract servo failed).
    • 8795
    I presume by "trim", you mean the decals? Just flew my Seawind this morning. When I first got the plane, right out of the box, I examined all the decals and where they looked like they could start to peel or were peeling, I just took a piece of Scotchtape and stuck it down. To date, nothing has peeled and I can't even see the tape. I'm very reluctant to apply any kind of heat to a foam plane. I never get the temp right and the last one I did, the foam all "gatored" up.
    • doctormike
      HobbySquawk Moderator
      • Oct 2013
      • 1260
      • Santa Fe NM
      I always give a new plane two coats of Varathane w.b. clear coat. This looks great and locks the decals down. Doc
        • 8795
        Taking this suggestion, I've purchase a small can of this product and will try it on my next plane, more to seal in the foam and make finger impressions less easy to make when picking it up. The sealing in of the decals would be an extra bonus.
        • boomer108
          Chief Boom
          • Apr 2014
          • 868
          • Chicago IL.
          I clear coat all my planes and now use Varathane per Doc's advise. Works great on keeping t h e decals down and protecting the foam.
          Roy B.
          • Pauly
            Just Fly It
            • Apr 2015
            • 469
            • Warsaw, NC
            Doc, Boomer what exactly is Varathane? I'm not familiar with that!
            Still Learning:D
            • boomer108
              Chief Boom
              • Apr 2014
              • 868
              • Chicago IL.
              Hey Pauly! Varathane is a product name just like Minwax. It's a water based clear polyurethane that comes in gloss and satin finishes and has a UV inhibitor that protects the foam from sun exposure. It can be applied with a foam brush very easily.
              Roy B.
              • doctormike
                • Oct 2013
                • 1260
                • Santa Fe NM
                Varathane poly is MUCH better quality than Minwax. No steaking. No bubbleing, and is flexible. Home Depot sells it. Gloss, satin, or flat. Doc
                • Pauly
                  Just Fly It
                  • Apr 2015
                  • 469
                  • Warsaw, NC
                  On one note just to make sure of.......it is foam safe?
                  Still Learning:D
                  • boomer108
                    Chief Boom
                    • Apr 2014
                    • 868
                    • Chicago IL.
                    Yes Pauly it's foam safe. Doc and I and others here use it on our foamies.
                    Roy B.
                    • Pauly
                      Just Fly It
                      • Apr 2015
                      • 469
                      • Warsaw, NC
                      Thank You, I'll have to try and find some.
                      Still Learning:D
                      • boomer108
                        Chief Boom
                        • Apr 2014
                        • 868
                        • Chicago IL.
                        I buy mine at Menards. I don't know if you have one in North Carolina, but try any of the big home improvement stores you should find it.
                        Roy B.
                        • Pauly
                          Just Fly It
                          • Apr 2015
                          • 469
                          • Warsaw, NC
                          No, I know we don't have one close by, but I'm sure I can find it at a home improvement store. There is a Ace Hardware here in my home town that has a really large section on all different kinds of paints and coverings. He may have it. But I would like to put a covering on my planes. They are all white, but as you guys stated earlier it will protect it from harmful UV rays and help protect it all together.
                          Still Learning:D
                          • doctormike
                            • Oct 2013
                            • 1260
                            • Santa Fe NM
                            Ace doesn't carry it in Santa Fe, just Home Depot. You can buy it on line. By the way, in some cases, I even use Varathane for glue. Doc
                            • Pauly
                              Just Fly It
                              • Apr 2015
                              • 469
                              • Warsaw, NC
                              I'm going to check in to it and get some. Thanks guys
                              Still Learning:D
                              • doctormike
                                • Oct 2013
                                • 1260
                                • Santa Fe NM
                                I also use it as a primer before I paint a plane. I am scratch building a plane out of foam board, which spray paint melts. Two coats of Varathane on the edges that are not covered with paper protects them from melting. Doc
