Foam dent removal
  • rvgary@me.com
    New RC Pilot
    • 7
    • (LA) Lower Alabama
    Foam dent removal
    I have some dents in my Timber wing from my first couple of landings. Does someone have any tricks on how to bring foam back to original shape?
    RVGARY
    A washcloth soaked with hot water will sometimes bring it out.
    • doctormike
      HobbySquawk Moderator
      • Oct 2013
      • 1260
      • Santa Fe NM
      I've tried everything you can find on the internet, with little luck. The worst of the dents, I just fill, sand and re-paint. Doc
        • 7418
        Yep, Foam-Tac, easy to work with and does the job
        • TomC
          • 79
          I have a few foam planes that got dents from transport. Get a paper towel fold so there are 4 layers, wet the paper towel so it barely drips,take a monokote iron set the temp 100-150 lay wet towel on dent area go over the area quickly with your iron look at area then keep going with iron in short wipes over the area looking at dent after each time til the dent is out..
          • doctormike
            • Oct 2013
            • 1260
            • Santa Fe NM
            Got to try that. Doc
            • rvgary@me.com
              New RC Pilot
              • 7
              Thanks for all the suggestions, will try every one. I have many dents in several airplanes.
              RVGARY
                • 7418
                Welcome to the club!
                LOL
                • RRHandy
                  Instructor Pilot
                  • 896
                  • Lilburn GA
                  This is how I do my repairs if I can get them in a pot of boiling water. :)
                  AMA 424553
                  • StormyDog1962
                    • 338
                    • Naperville Illinois
                    Just be careful with the Hot Water, I will heat some up in a Tea Kettle and then slowly pour it over the dents and watch them slowly pop back out. Just take your time cause if you get in a hurry and over do it you could Alligator the foam. Filling them and doing some touch up painting works great also but an easier method is you can lay a narrow strip of Trim Kote over the Leading Edges once you fill in the dents. https://www.motionrc.com/collections/trim-sheets Choose a color that helps the front edge pop out at you as this can also aid in orientation.
                    • TomC
                      • 79
                      I need to add to my post above, USE FAUCET COLD WATER ONLY WHEN WETTING DOWN THE PAPER TOWEL.... I feel using faucet cold water on the paper towel and heat Iron on low temp this slows down the foam expanding process, the Alligator look is hardly seen to none at all..This method works Great for me...:)
                      • rvgary@me.com
                        New RC Pilot
                        • 7
                        I enjoy reading your great advice on everything foam... One more question; what do you use as a filler???
                        RVGARY
                        • doctormike
                          • Oct 2013
                          • 1260
                          • Santa Fe NM
                          I use Elmers wood filler, white. It dries quickly, is light, easily sanded, and stays put. MRC sells a filler that gets good reviews, also. Doc
                          • rvgary@me.com
                            New RC Pilot
                            • 7
                            Thanks Doc, will give it a try...
                            RVGARY
                            • Kloverzero
                              JetManMichael
                              • Dec 2015
                              • 513
                              • Conway SC
                              Beacon Foam Filler - 8oz This stuff is fantastic for filling in minor surface imperfections, all the way up to major chasms. It adds virtually no weight, dries hard and quickly, and sands super easy.
                              • StormyDog1962
                                • 338
                                • MCO3024
                                  • Aug 2016
                                  • 33
                                  Hobby Lobby sells a product made for filling foam. Very light, sandable and easy to use.
                                  • Pauly
                                    Just Fly It
                                    • Apr 2015
                                    • 469
                                    • Warsaw, NC
                                    MC, I know how the Beacon product that MRC sells works. I would suggest using that. Use the filler, sand it then apply some foam finish, sand then some hobby coat and it'll look 10 times better then before the dent.
                                    Still Learning:D
                                    • skylane42
                                      • Jun 2015
                                      • 19
                                      • Portage, MI.
                                      Will the hot water method for removing small dents hurt the paint ?
                                      • dahawk
                                        Augermeister
                                        • Jun 2013
                                        • 1006
                                        • Keller,Texas
                                        Sometimes when using the hot water treatment, you'll get the gatoring or beading of the foam. One trick I learned to get rid of the dreaded gatoring is to take a pre-cooled big soup spoon and as soon as the gatoring appears, rub the affected area with the back of the cold spoon. Works great. You can watch the gatoring go away right before your eyes.
