Bind plug
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    Bind plug
    I always put in an extension plug-in for binding, just in case I have to re bind. Really makes it easyer! Doc
    Absolutely...real time saver.
    • Lon
      • Jul 2014
      • 1202
      • Miles, Iowa
      I didn't realize it untill installation of the newer Spektrum receiver a month ago (AR6600T) But it has a Bind button! Handy/convenient i do say.
      Lon
        That's good to hear, it's about time they did that.
        • Capt. Crunch
          Balsa flies better
          • Nov 2014
          • 388
          • Iowa
          I have a couple planes I use that "channel" for lights.
          If I put a Y harness in to power the lights, could I still rebind through the empty lead? .
            Yes because it uses the ground and signal wires to bind and you're using the ground and power for the lights.
            • Capt. Crunch
              Balsa flies better
              • Nov 2014
              • 388
              • Iowa
              So it would just kill the lights while binding. I might have to rig that up on those planes. I don't rebind very often, but that could come in very handy when I do
                It shouldn't.
                • Capt. Crunch
                  Balsa flies better
                  • Nov 2014
                  • 388
                  • Iowa
                  Oh right, I guess It would't cut power to the lights... this electrical stuff...:Dizzy:
                  • doctormike
                    • Oct 2013
                    • 1260
                    • Santa Fe NM
                    That should work just fine. :Cool:Doc
                    • doctormike
                      • Oct 2013
                      • 1260
                      • Santa Fe NM
                      Only problem with the Rx bind button is, on some planes (Freewing A-10) the reciever is inaccesable. Also... how do you hold down the Rx bind button and the Tx bind button at the same time?:Confused:Doc
                      • Kloverzero
                        JetManMichael
                        • Dec 2015
                        • 513
                        • Conway SC
                        If it works like my Futaba, you turn on the radio and press the bind button on the receiver until the light is solid. Haven't got a Spektrum receiver with a button yet.
                          • 8831
                          I have seen several Eflite planes (& other Horizon products) use extensions on their BNF Spektrum Rx's to bring the bind port to a more convenient location. Since a bind plug is just a jumper between the two outer pins on the port, any 3-wire extension cable will do. This can then be used to power lights, etc. when not being used for binding. On some Lemon Rx's, the bind port doubles as AUX2.
                          I have not seen Rx's that bind with a button. To me, this is one more extra piece of "fiddly". As said before, now you need another hand (finger) to do the binding. The Lemon Rx's with failsafe need to have a button held when binding in failsafe. I've done this once and it was tricky (for me) - needed to be a bit of a contortionist to get it done.
