Roc Hobby Waco
  • boomer108
    Chief Boom
    • Apr 2014
    • 867
    • Chicago IL.
    Roc Hobby Waco
    I just received the Roc Hobby Waco today from Motion Rc , it took 1 1/2 days.Those guys are amazing! My question is has anyone put Dave Brown's on one and what size? I just don't care for the wheels it came with. Thanks
    Roy B.
  • retiredflyer
    • Aug 2014
    • 333
    • Sanford, Maine
    RE: Roc Hobby Waco
    Hi boomer,
    I didn't like the original wheels either. I swapped mine out with an extra set from my Hobbyzone Supercub. Almost an exact fit. The fairings make it tough. The Supercub wheels are softer like the Dave Brown's. I just had to drill out the axle holes a tiny bit. There is a ton of discussion about this plane on a thread at RCgroups.com. I have only taken mine out for her maiden before winter hit, but it flew great.
    Addicted to planes!
    • doctormike
      HobbySquawk Moderator
      • Oct 2013
      • 1260
      • Santa Fe NM
      RE: Roc Hobby Waco
      I absolutely love the Dubro low bounce wheels. I never use the stock wheels. My planes that are the same size as the Waco have 2 1/2" or 3" low bounce wheels. They work great on grass. Some trimming is usually needed on the fairings. I use a Dremel or a die grinder for this. Have fun! The Doctor
      • boomer108
        Chief Boom
        • Apr 2014
        • 867
        • Chicago IL.
        RE: Roc Hobby Waco
        Thanks for the advice guys. I will try those wheels out. Thanks again.
        Roy B.
          • 7333
          RE: Roc Hobby Waco
          And watch your control throws! Mine went 3d the first flight!  Also, she was tail heavy.  Had to add weight to the cowling to settle her down.
          • boomer108
            Chief Boom
            • Apr 2014
            • 867
            • Chicago IL.
            RE: Roc Hobby Waco
            Thanks Grossman! I'll make sure to keep her in low rate for the maiden. As far as the cg I have found my Great Planes cg machine invaluable for balancing. I'll make sure to check it. Thanks for the tips. You can't beat the forum  for people helping each other out. Thanks again.
            Roy B.
              • 7333
              RE: Roc Hobby Waco
              Ah the nightmare called "getting the CG machine arms through the rigging"  Probably easier to take it off.  BTW, did you get the stretchy string we've all used for rigging? It's fine elastic thread and works so much better than the stuff they give you.  Some of the guys found it at Walmart in the sewing section, I got mine at Amazon.  I'll see if I can dig up the thread, should be in "All Us Newbie Pilots....'
              http://www.amazon.com/dp/B00G9K3R96/ref=pe_385040_121528360_TE_dp_1
              • boomer108
                Chief Boom
                • Apr 2014
                • 867
                • Chicago IL.
                RE: Roc Hobby Waco
                I haven't bought it yet going to try a local Michaels Craft Store. If they don't have it I will use the Amazon thread you gave me. I'm currently Minwaxing the plane, looks great so far. That's what I like about this hobby, I haven't even got the plane together and already I'm upgrading the wheels, I've got the external 10a bed to put in and I may change the servo's if their not metal  gear servo's. I did notice they have upgraded the esc to 40a from 35a so I won't have to change that,isn't it great to modify brand new stuff ha ha! Thanks again for the advice Grossman.
                Roy B.
                • retiredflyer
                  • Aug 2014
                  • 333
                  • Sanford, Maine
                  RE: Roc Hobby Waco
                   I was able to stick with the stretchy string supplied with the plane.  I just started by tying a knot onto a spring first (not connected to the plane) with a foot long piece of the thread.  I pulled the knot REAL tight and put a drop of CA on the knot.  I let it dry overnight and then attached the other spring to the plane and pulled the thread through and stretched it and tied another knot with CA.  Trimmed the loose ends and all is fine.  No problems what-so-ever.
                    Seems a lot of people have had issues with the supplied thread.  I was able to get mine to work so I stuck with it.  And yes, I did the CG check BEFORE I didn't he rigging.  Much easier.
                    I was soooooo impressed when this plane lifted off for my maiden last fall.  I actually did not have to adjust any trim.  It was perfectly flat in flight with the Admiral 2200.   My low rates are 40% expo and 60% throw.  Worked great for me.  I never use the throw numbers in the instructions either.  My throws are based on using 100% of the available travel of the aileron/elevator/rudder as the baseline.  I then just crank the travel down with my radio to 40/60/80, or whatever I like.  I think I have been always starting with 40% expo and 60% throw for almost every plane I own.  Rarely do I have to crank the throw DOWN any.  Usually I go up in throw as I get more comfortable.
                    Keith
                  Addicted to planes!
                    • 7333
                    RE: Roc Hobby Waco
                    No Problem Boomer!  That's good advice too Keith, words to live by.  I put mine on a graduated switch so I can start off on minimum, go to switch position 2 and have the throws increased by 10 then position 3 with another 10. In the Waco I believe the top throw setting was 70% (that was on my DX6i with 60% and 70% on a two way switch)
                    • Rocketeer
                      • Feb 2014
                      • 1356
                      RE: Roc Hobby Waco
                      Greetings Boomer108,
                      I've been flying the Roc Hobby Waco for a while and I really adore flying it.
                      This is truly an out of the box flying machine!!
                      I like to vary the flying characteristics by switching it up between 1600, 1800 and 2200mAh LiPo's.
                      Either way, all this plane wants to do is fly.
                      You've more than likely already noticed how well engineered it is and the assembly is a snap!!!
                      Best of luck and I look forward to hearing your thought as you work towards completion of your Waco.
                      Clear Slies
                      Bill L.
                      in Okla.
                        • 7333
                        RE: Roc Hobby Waco
                        Bills right, she does like to fly.  For the fun of it, I put a long piece of ribbon around the rear pilots neck so he has a scarf blowing in the wind, it looks way cool!
                        By the way, she doesn't like to keep her pants on!! did a mod that I covered in All Us Newbies. and it was semi successful. I combined it with some Elmers Rubber Cement on the upper end of the pants that touches the fuselage. It looks good, just waiting for the weather to clear to try it out
                        • Rocketeer
                          • Feb 2014
                          • 1356
                          RE: Roc Hobby Waco
                          Greetings Gman,
                          In hind site I neglected to ask Boomer if he ordered the yellow or the red and white.
                          I'm glad you inserted your beauty in the avatar so he could get a look see.
                          Bill L.
                          in Okla.
                          • boomer108
                            Chief Boom
                            • Apr 2014
                            • 867
                            • Chicago IL.
                            RE: Roc Hobby Waco
                            Originally posted by Rocketeer
                            Greetings Gman,
                            Bill L.
                            in Okla.
                            Hey Rocketeer!
                            I ordered the yellow one. I started assembly tonight after putting two coats of Minwax, man does she pop! My wife loves so much she wants me to get the red one also,her two favorite colors. Sounds like a bonus to me. Anyway I installed a 10a bec along with my favorite xt-60 connector and I have some Dave Brown's to to put on also. The assembly is easy and everything fits tight but the instructions leave a lot to be desired and wheels pants terrible! I had the same idea as Grossman on how to mount them along with some Welders adhesive, flexible and strong. Which way do you guys find the best way to install the battery? That compartment is tight. Well I will continue the assembly and keep you posted.
                                   Good flying!     Roy B.
                            [hr]
                            By the way Grossman your red Waco is beautiful! I'll post pictures of mine as soon as I figure out how.
                            Roy B.
                              • 7333
                              RE: Roc Hobby Waco
                              I put mine as far forward as I can and added about 10 oz inside the cowling.  She behaves herself pretty good now, but like I said, watch your throws on the elevator especially.  One thing about the pants, I trimmed a small amount (like 1/8") off the bottom so there was some room for flex.  The clasps on mine just don't want to stay on the gear legs, so I did that little mod and hopefully this will solve the problem.  Bill has had great success with his Waco, mine was a challenge and I don't know why mine needs as much weight up front, but thats the way it is.  I'd suggest CGing her before putting on the wires.  She's a feisty little gal but a lot of fun, plus she looks awesome in the air!!
                              By the way, what size Dave Browns? I have 3" DBs on my Pandoras and love them
                              My wife loved the white and red as well, maybe if I just keep buying red and white planes she won't notice!!
                              Grossman6
                              • Rocketeer
                                • Feb 2014
                                • 1356
                                RE: Roc Hobby Waco
                                Greetings,
                                As GMan mentioned, I had no issues or need for additional weight with my Waco.
                                I simply install the batteries as far forward as they'll go and fly.
                                Although, when I incorporate the 2200mAh I don't go quite as far forward.
                                I did however, CG my Waco after I rigged it out.
                                I have the yellow Waco but, I am a big fan of the red and white version as well.
                                Bill L.
                                in Okla.
                                • Flygirl
                                  • 969
                                  • Glen Burnie, Maryland USA
                                  RE: Roc Hobby Waco
                                  Grossman6
                                  Don't want to hijack this thread but if I could ask a quick question Grossman? Those 3 inch tires for the Pandora, did you mean as a tail dragger? Or Trike? Just curious.
                                  By the way, Love that Waco. I used to have one I made back in the early 80's with a .60 engine in it. Can't remember what brand it was. Pico maybe? Pica?
                                  Lauren
                                    • 7333
                                    RE: Roc Hobby Waco
                                    The picture thing is a little tricky, I have to go into my photoshop program and resize anything I want to post I resize to approximately 1000 and then save it in a folder called web shots.
                                    Then, when you're posting, go to the bottom of the page and hit browse to find the picture, select it and then hit "Add Attachment" on the left and it will start the process.  The picture will either end up showing on the right side, under the "Add Attachment" button or it will tell you that its too big.  Assuming that it shows up on the right, you click back on the post to where you want it to show up, then click the "insert into post" button, and there she is, hit the "preview post" button to check it out before you post it.
                                    • Hippie 64
                                      • Feb 2014
                                      • 1049
                                      • Gaffney , S.C.
                                      RE: Roc Hobby Waco
                                      Hey Flygirl I have those wheels in route to me for my Pandora . I don't think you can use them in the Tric setup . I plan to have for tail dragger for switching between the two styles .
                                      Bryan
                                      But Crashing is Landing
                                        • 7333
                                        RE: Roc Hobby Waco
                                        Grossman6
                                        First, I should have said 10 Grams not oz in the nose of the Waco, oops.  And yes I have both in low wing tail dragger config.  The 3" DB's look great! Now, your CG is going to give you fits!  I have both my Pandoras set up this way now and the battery compartment became the ESC compartment as I put in 50A esc's in both.  The battery sits underneath the canopy right against the main spar, which is as far back as I can get it without cutting.  Now, here's the interesting thing.  Two Pandoras set up exactly the same, go to CG them on a Great Planes CG machine. P-2 sits up there as pretty as you please. P-1, however was nose heavy still, so I had to add 7 grams to the tail.  A little razor bladingand I managed to recess it into that little flat spot at the rear of the fuselage.  I had epoxy/resin it into place, but it worked.  The point is, two exactly the same planes (except for paint) two very different CGs.  Same with my Waco versus Bill's guess some days they lean on the foam injector more than others!
                                        [hr]
                                        yes, they'd be too big for a trike set up
