Anyone know what kit this is?
  • Theodan
    • Jul 2018
    • 4
    Hi, I bought this plane used. Does anyone know what kit it is? I am looking to install my radio, but would like to see if I can find a manual for it. The wingspan is approx. 65".
  • fhhuber
    • Aug 2015
    • 1476
    Has resemblance to PT-19, PT-20, Miles Magister... but not quite right for any of those
    Maybe...
    Flugzeuginfo.net is the comprehensive civil and military aircraft encyclopedia with photogallery, airport-codes, airline-codes, aircraft-codes, country-codes, NATO-codes, aviation museums and much more.
    • F22trainer
      Piper PhD
      • Mar 2018
      • 1484
      • Sun City, Az
      Not sure either but I think a Chipmunk mated with a Tiger Moth...
      • fhhuber
        • Aug 2015
        • 1476
        Could be closer to that than you think...
        • themudduck
          -TMD- Foaming at the Mouth!
          • 1041
          • Burton OH (near Cleveland)
          The shape of the fin is the giveaway...that is absolutely a dH Moth Minor, no doubt. But I can't find it anywhere as a kit. It may have been scratchbuilt from plans.
          The real plane had an interesting-looking "flap" with holes in it, underneath the center of the wing.
          • fhhuber
            • Aug 2015
            • 1476
            That style "flap" is a dive brake. Its not really a flap. Its for drag only, not to alter the wing's lift.
            Possibly the design had issues with just floating along the runway in ground effect. I can't see any other reason to add it.
            The model's wing has significantly less taper than the full scale aircraft, making me think someone modified a PT-19 kit, sweeping the LE back instead of the TE forward.
            • JFandL
              • Jun 2013
              • 402
              Whatever it is, hope your going to fly it soon. looks like they did a good job building it.
              • F22trainer
                Piper PhD
                • Mar 2018
                • 1484
                • Sun City, Az
                I saw a kit for this - and it was made in Eastern Europe - recently on eBay. Almost bid on it, but I have no idea who the manufacturer was. Everything pictured on the box was written in German (I think), but showed instructions written in English.
                  Could it have been a carson? I bought several Carson models when I was stationed in Ktown
                  • fieldofdreamsflyer
                    Banned
                    • Jan 2013
                    • 289
                    DHC-1 Chipmunk
                      Banned
                      • Jan 2013
                      • 289
                      Nope not that
                      • themudduck
                        • 1041
                        Originally posted by fieldofdreamsflyer
                        Nope not that
                        Looking carefully at pictures of the Chipmunk and Moth Minor, you can see that these are really similar planes if you ignore the cockpit canopy which is missing from the model in question I think I finally noticed what's really the defining difference. Its in the tail.
                        On the Chipmunk t
                        he horizontal stab
                        is set further back, the elevators are behind the rudder.
                        With the Moth Minor the rudder sticks out well behind the elevators..
                        So I agree with you, the model appears to be a DH Chipmunk. Don't ever tell me that I won't admit when I'm wrong! :Straight-Face:
                          Oh hell no brother, I like my teeth where they are, and I had a good nights sleep!LOL;):Cool:
                            Banned
                            • Jan 2013
                            • 289
                            On the Chipmunk t
                            he horizontal stab
                            Sorry about that
                            • themudduck
                              • 1041
                              I'm just joking!! I mean, I was wrong and I admit it!
                              Well, I admit it this ONE time... but I'm not going to make a HABIT out of it..... :Cool:
                              Image result for i admit that I am wrong
                              • Theodan
                                • Jul 2018
                                • 4
                                Hey guys sorry for the late reply. I really appreciate all the info. I am just trying to determine how to set up the centre of gravity and your info helps to narrow down possible model kits to look at. Thanks
                                • themudduck
                                  • 1041
                                  Hey it's no problem, we had a little party while you were gone, got drunk, trashed the place and left it in a mess! So now you're back!
                                  It shouldn't be hard to get this plane going - balance it at 25% back from the LE of the wing (at the fuselage) - that will be slightly nose-heavy, and it should fly very well. You may need just a bit of "up" trim. Then after a couple of flights you can try moving the balance back slightly until it flies just the way that you like it. If you want to cruise, leave it nose-heavy. If you want to do aerobatics, then edge it back until it flies inverted with just a hint of down elevator to keep it level. You should be fine with this plane.
                                  • Theodan
                                    • Jul 2018
                                    • 4
                                    LOL looks like a party! I'll set up the C of G as you have said and go from there. I think I will look for a canopy and call the model a sport Chipmunk so I can use it at scale rallies! So thanks a lot everyone for the info. I am just getting back into flying after many years away. I have a couple Eagle 2s and a Great Planes cub to practice with for a bit as I get comfortable again.
