I have an E-Flite P47D Razorback 1.2m and it's manual says to set the dual rates to 100% High and 70% Low.
However, the Spektrum receiver that came with the aircraft only allows a percentage rate that sets two numbers at the same time in the DR/Expo menu.
For example, if I move the DR to 100% it sets both numbers at the same time.
Lowering or raising the number does it to both at the same time.
There is no way to seemingly set 100% and 70%.
Also, there is a nice chart in the manual showing dual rates in mm's.
Not sure why one chart shows it in percentages and the other in mm's.
Also, no way I can find to set mm's in the Spektrum RX and TX.
Any help would be appreciated.
