Sounds to me like he's drank the Kool Aid of R/C flying, he's hooked now
Tail draggers like to pull to the left when taking off and landing, so what you may have thought was over use of rudder , might have been the P factor, be prepared to apply right rudder, the narrower the landing gear the more likely. The Spitfire loves to do that as well so I'm on the rudder when landing and keeping the prop spinning at idle (which I interpret as being the throttle setting needed to break the inertia and make the plane move)
On takeoffs, once the tail is in the air and the vertical stab gets some air moving over it, she'll lock in, the trick is getting it to where the tail is in the air.
