I have flown RC choppers and now want to get into fixed wing. I am going to buy the freewing A-6 Intruder, but i want to get something that will help me transition into that airframe. Any suggestions?
Will be buying the A6 Intruder, but also want something to help transition from choppers
Hello TrainmanMike and welcome to the Squawk.
Transitioning from a rotary to fixed wing or vice versa is a skill set of different animals.
Fixed have a whole different carry of inertial momentum as well as how they behave with high or low wing placement and whether it is trike gear or tail dragger.
Get a prop trainer preferably in trike and then from there a EDF trainer like say the Avanti and then the "Iron Tadpole"
With your heli experience, I would guess the transition will be short and rather uneventful but take your time
Best regards,Warbird Charlie
I've had a chance to fly the OV-10. It's a heavy plane and I find the power to be somewhat marginal for aerobatics but yes, fairly stable.
It's actually also pretty quick though, I'd expect 75 mph give or take.
I think the challenge on this one will be landing. It will stall at a faster clip than some and given the higher weight, even though the gear are good, if you stall from 2-3 ft. up and drop it in, you're likely to have damage.
