Pilot Painting
  • jetfool
    • Nov 2022
    • 1286
    • Crawfordsville, Indiana
    Grossman56,
    Those guys are going to look great when finished. Wish I had your talent's, Dan.
    Best Regards, Rex
    • NCO Retired
      • Jul 2026
      • 53
      • Mid-state Illinois
      What can I say Dan!!!! I'm going to really test your talent in my next box to you, hint: Lucky Strikes.
        • 7340
        Well, the paint didn't adhere very well to the material these figures are made of, so I scrubbed it off with some water and a tooth brush and sprayed the bunch with black primer. Really should have done that in the first place, but live and learn.
        A bunch of new paint arrived today that is dedicated to Allied and German uniforms. As there aren't a whole lot of color pictures out there of WWII era soldiers, this should help to zero in on the correct colors. Reenactment soldiers are good as well to get a start, but I'm pretty sure the uniforms didn't go home at night and be washed, pressed and put in some form of protected storage.....
        Heading down to play with them some more.
        BTW, toothpicks pressed into foam, insert the straws. Makes a great stand.
        (Dangerous Dan)
        • NCO Retired
          • Jul 2026
          • 53
          (Dangerous Dan)
          Sorry to hear that Dan...........
            • Nov 2013
            • 2690
            • Cody, WY
            I like your starting the process with the black primer as a base coat. Look forward to seeing how they turn out using this process!
            Cheers
            Davegee
              • 7340
              Just got finished with probably the tenth pass over the fie heads, finally starting to look like I have something here.
              As a comparison, here's the size I've worked with thus far as compared to the 'little people'
              Click image for larger version  Name:	20260831_110831.jpg Views:	0 Size:	94.2 KB ID:	452280
              So here's the gang!
              Click image for larger version  Name:	20260831_110715.jpg Views:	0 Size:	143.1 KB ID:	452276 Click image for larger version  Name:	20260831_110726.jpg Views:	0 Size:	125.9 KB ID:	452277 Click image for larger version  Name:	20260831_110746.jpg Views:	0 Size:	143.9 KB ID:	452278 Click image for larger version  Name:	20260831_110753.jpg Views:	0 Size:	120.7 KB ID:	452279
              Everyone has a different expression, the difficulty is not making them look all the same facial tone-wise.
              Coming along, Got to buy some good old Testors Glue to assemble the parts...
              (Dangerous Dan)
