Pilot Painting
  • jetfool
    • Nov 2022
    • 1325
    • Crawfordsville, Indiana
    Grossman56,
    Those guys are going to look great when finished. Wish I had your talent's, Dan.
    Best Regards, Rex
    • NCO Retired
      • Jul 2026
      • 67
      • Mid-state Illinois
      What can I say Dan!!!! I'm going to really test your talent in my next box to you, hint: Lucky Strikes.
        • 7369
        Well, the paint didn't adhere very well to the material these figures are made of, so I scrubbed it off with some water and a tooth brush and sprayed the bunch with black primer. Really should have done that in the first place, but live and learn.
        A bunch of new paint arrived today that is dedicated to Allied and German uniforms. As there aren't a whole lot of color pictures out there of WWII era soldiers, this should help to zero in on the correct colors. Reenactment soldiers are good as well to get a start, but I'm pretty sure the uniforms didn't go home at night and be washed, pressed and put in some form of protected storage.....
        Heading down to play with them some more.
        BTW, toothpicks pressed into foam, insert the straws. Makes a great stand.
        (Dangerous Dan)
        • NCO Retired
          • Jul 2026
          • 67
          (Dangerous Dan)
          Sorry to hear that Dan...........
            • Nov 2013
            • 2745
            • Cody, WY
            I like your starting the process with the black primer as a base coat. Look forward to seeing how they turn out using this process!
            Cheers
            Davegee
              • 7369
              Just got finished with probably the tenth pass over the fie heads, finally starting to look like I have something here.
              As a comparison, here's the size I've worked with thus far as compared to the 'little people'
              Click image for larger version  Name:	20260831_110831.jpg Views:	0 Size:	94.2 KB ID:	452280
              So here's the gang!
              Click image for larger version  Name:	20260831_110715.jpg Views:	0 Size:	143.1 KB ID:	452276 Click image for larger version  Name:	20260831_110726.jpg Views:	0 Size:	125.9 KB ID:	452277 Click image for larger version  Name:	20260831_110746.jpg Views:	0 Size:	143.9 KB ID:	452278 Click image for larger version  Name:	20260831_110753.jpg Views:	0 Size:	120.7 KB ID:	452279
              Everyone has a different expression, the difficulty is not making them look all the same facial tone-wise.
              Coming along, Got to buy some good old Testors Glue to assemble the parts...
              (Dangerous Dan)
              • NCO Retired
                • Jul 2026
                • 67
                So here's the gang!
                (Dangerous Dan)
                ...and it's a great job with those facial expressions Dan!!!
                  • Nov 2013
                  • 2745
                  • Cody, WY
                  Looking Great, Dan!!
                    • 7369
                    Ah the little people in the basement:
                    They're coming along, uniforms and helmets roughed in :
ID:	452409 Click image for larger version
ID:	452410 Click image for larger version
ID:	452411 Click image for larger version
                    Some more work to be done on the faces to get the cartoonish look a little less. I find if I can get the surrounding colors working, it helps a lot.
                    (Dangerous Dan)
                    • NCO Retired
                      • Jul 2026
                      • 67
                      Amazing!!!! Can't wait to see your work on the next three I send you, three 101st AB trooper tank riders.
                      Thanks for the photos and update.
                      Ed
                        • 7369
                        Yes, a bit at a time. Once I'm finally retired (Jan 22) I'll have more time. I remember my mom saying that she was glad she was retired because she just didn't have time to go to work!
                        Wise words. Old gal is stiil kicking, coming up 100 next year, hard to believe.
                        (Dangerous Dan)
                          • 7369
                          An update on the tanker guys.
                          Assembling these figures is a nightmare, did the best I could but man, a hole in the center of each piece and using a small piece of brass tube would work much better.
                          Anyways, most of them are looking pretty good...
ID:	452582 Click image for larger version
ID:	452583 Click image for larger version
ID:	452584 Click image for larger version
ID:	452585 Click image for larger version
                          (Dangerous Dan)
                          • NCO Retired
                            • Jul 2026
                            • 67
                            Mighty fine work there Dan!!!!!
                              • 7369
                              Oh those guys!
                              They're always hamming it up lately as they get close to completion!
ID:	452816 Click image for larger version
                              (Dangerous Dan)
                              • NCO Retired
                                • Jul 2026
                                • 67
                                Some 101st Airborne troopers have landed on your porch, they brought along a case of rations and some wine....bottles!!!!
                                  • 7369
                                  Indeed they did, they're waiting rotation through Currahee!
                                  (Dangerous Dan)
                                    • 7369
                                    Whew, just try painting rank insignia and group crests on 1/16 figures, enough to make you cross eyed!
                                    (Dangerous Dan)
                                      • 7369
                                      The boys are on the home stretch, should be able to finish them this weekend. Once done, I'll rotate the first five back home to the ZI.
                                      (Dangerous Dan)
