Pandora landing gear
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Been flying in the tail drag for a while and wanted to change up , went to tricycle . I'm having a constant issue with the nose on landings . I know some are a little rougher than others but no matter how soft the nose keeps coming apart or twisting . I've tightened and adjusted but nothing helps . Anyone else have issue or advice ?
    But Crashing is Landing
  • MDBassPlayer
    • Jul 2014
    • 3
    Re: Pandora landing gear
    I had the same issue when trying to fly off of a soccer field that had broken grass/divets everywhere. The nose gear just isn't going to work unless you have very smooth grass. Even a metal gear servo will not survive.
    Now that I am flying on a better field (steamrolled at least once a season and cut regularly) with a club I am about to switch back to tricycle gear and will get back to you.
    • Lon
      • Jul 2014
      • 1202
      • Miles, Iowa
      I've been flying my Pandora for 7 weeks now, and I fly almost everyday. I had seen a few postings with same issues as you. And what I've done, is taken the easy way out, only flying as a tail dragger...This may not be much help to you. But it's worked for me!
      Lon
      • WintrSol
        • Nov 2013
        • 499
        • Florissant, MO
        One of the weaknesses in the design is the forward-bent nose gear. The slightest amount of sideways force on the wheel will yank, hard, on the servo. I haven't tried the tricycle configuration because of this, just high- and low-wing tail dragger.
        • Hippie 64
          • Feb 2014
          • 1049
          • Gaffney , S.C.
          Thanks Bassplayer , looking forward to hearing back . Hope its all positive . I think I like the tric look much better plus been tail dragging for a while with it
          • MDBassPlayer
            • Jul 2014
            • 3
            Hey,
            Sorry for the long delay... Just had to have surgery. Hopefully I can get flying again in two weeks.
            • Hippie 64
              • Feb 2014
              • 1049
              • Gaffney , S.C.
              Hey Bassplayer hope all is good and nothing terminal !!! I reinforced the top and bottom of the plastic on the nose with balsa and epoxy . So far so good , just have to try and give it a soft landing. I do wish it had a compression strut on the nose would have made a world of difference . GLAD YOUR BACK !!!!
                • 7417
                Hey, one of these days we'll have to have a Pandora fly in!
                I wonder if MotionRC would be into putting on some sort of get together with any of us that could make it. It would be a heck of a get together!
                • ServiceRep
                  • 2
                  RE: Pandora landing gear
                  The 4" foam wheels on my tail dragger landing gear did not always rotate as freely as I would like. They would bind a little where the axle is bent. There is not enough axle length to put a wheel collar on both sides of the wheel to help it spin freely.
                  My fix was to tie a thick piece of string twice around the axle, and add 2 small washers to make a little wheel collar. I put some clear nail polish on the string to hold it in place.
                  Now the wheels spin perfectly.
                  Landing is mandatory!
                    • 7417
                    Hey ServiceRep, welcome to the forum!
                    Good idea, I got tired of chewing the foam tires up and went 3" Dave Browns on both my Pandoras.
                    They're great!
                    I also got tired of replacing landing gear so I took the screws out of the small plates that lock the LG onto the fuse and Epoxy/resined them into place, I also wrapped the pants with color matched electrical tape.  Works great for extra strength!
                    • STOOPIDMONKEY
                      • 319
                      You can install the dubro 1/2A nose gear. I used it on my V1 skytrainer 182 never had any issues with it.
                      http://www.motionrc.com/dubro-1-2a-steerable-nose-gear/?gclid=CjwKEAjwlsSoBRDoid2ihqnjjlISJABZoG9-bF8pj7de8lRsd9YXWKk1GpfoJxM_uPyAHgkuk5DFsRoCGT_w_w cB
                      Flight Risk (Sean)
                      AMA # 986105
                        • 7417
                        Hey, has anyone heard from Bassplayer!  Hope he recovered from his surgery alright.
                        Haven''t heard from him in a while.
