First thing is to bind the RX and TX together. That wire with the metal ring is the line from the BEC and it powers the RX. Before you plug anything else into the RX, plug that wire into any port in the RX (note polarity). Use bind plug in the bind port. Go through the usual bind procedure. You'll only need one battery on the plug that also has the BEC on it. After the bind, unpower everything, remove bind plug and put the wire with the ring into bind port (this is also the battery port). Now plug everything else in where they go and do the usual throttle calibration and servo centering and setting.
New Guy Questions
.png)
