New Guy Questions
    • 8754
    Originally posted by Aerodude
    Hello all, I'm Newark need some help with my freewingA10. There is a long wire with a round metal attached to it. Where do I plug this in on receiver?
    First thing is to bind the RX and TX together. That wire with the metal ring is the line from the BEC and it powers the RX. Before you plug anything else into the RX, plug that wire into any port in the RX (note polarity). Use bind plug in the bind port. Go through the usual bind procedure. You'll only need one battery on the plug that also has the BEC on it. After the bind, unpower everything, remove bind plug and put the wire with the ring into bind port (this is also the battery port). Now plug everything else in where they go and do the usual throttle calibration and servo centering and setting.
    • crankestein
      • 316
      Make sure motor is NOT connected during binding or at least the prop not attached to it.
